Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1446949 04/03/2022 11:37 PM
GPK 1961
GPK 1961
Good afternoon from Texas.
I have a 1961 Chevrolet Apache 10, 235 engine.
I have replaced the generator and voltage regulator and I still have no charging. The generator light stays on and will eventually drain the battery. I pulled the positive cable and it will stop running. I polarized the replacement generator and trickle charge the battery when it runs down. It will run great when the battery is charged, have temp gauge, horn, wipers and some lights (this is an old work truck) -- what would you check next? gpk1961
New project - 1961 Apache 10 Step-side
H Online: Content
If you want to fix what you have, send me a PM.
Let us know what you find. I have a completely stock 49' 3600 so any knowledge I can glean in case my charging system ever acts up would be nice to file away
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Sir Searchalot
Sir Searchalot
If you decide to go alternator. I can help.
Chevy trucks went to alternators in 1963, so not a real stretch.
Moderator, Electrical Bay
Where in Dallas are you?
~ Jon
Jon G #1447020 04/04/2022 5:06 PM
GPK 1961
GPK 1961
Hello Jon -- I am in Frisco, 121, and Independence.
There are experts here that will guide you through which ever process you decide to embark on, there are pro's and con's to both methods of keeping your battery charged.
Another quality post.
Real Trucks Rattle
GPK1961 Would go to alt.in a heartbeat,your already 12 volt once you change all your charging troubles will be in one unit. If trouble comes even on the road any parts store can help you. No use of fighting antiques from another century !!
gpk1961 Also can use your gen light to stay stock looking on your dash,smooth clean set-up.
gpk1961 A friend always calls me to refresh his memory on just what you are doing. I suspect your done by now but others might use this. From the alt. output post put a jumper to the farthest away 1/4 inch flat terminal,put the other terminal to your dash light wire,send the big output post to charge the battery. Turn on key gen. light comes on start engine gen light goes out,alt makes a special noise when charging,also gets warm,feel where the two halves meet laminations there heat up.
