4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
Well it is finally time to put everything back together! So here is the first hurdle that I have come across. Old vacuum advance was bad, engine rebuilder found me a replacement. It is the universal one that everyone has on their sites. I have no issue with it. The issue that I have is that the clamp to the Distributor will not work with this Vacuum Advance.
My old VA sat at a roughly 30 degree angle from the engine. The new one is inline with the engine.
" First question is "What is this Called?"
Second question is "Where do I get this part?"
I didn't see it listed on either Jim Carters or Chevy's of the 40s websites.
As always THANK YOU in advance. I am ever so Grateful for this wonderful source of knowledge, support and wisdom
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
I believe that the 30 degree one is for a car so that it clears the side motor mount. I have an 235 from a '53 car that is that way.
Brian Moore Now I am a big fan of updates and if you like original that is fine. If you go to HEI you'll save yourself a lot of misery with related problems plus you'll get powerful ignition. Also you can modify an early HEI (not computer controlled) right at home probably with tools you have 4 inch grinder,drill,hacksaw,file. I find a clean used donor distributor at the junkyard,make it same dimensions as the one that is in there.Good Luck !!
Send me a PM with your snail mail address- - - -I've got the part you need.
Thanks for the replies everyone. I really appreciate all the help. John and Peggy you two have created a great community!
Brian Moore
Now is the time to pull the point plate, clean all the junk out of the bottom, make sure the springs and spring posts on the advance are good, lubricate the advance weights to make sure they are free and fling out easily. If the weights are rusty or hanging up, you can bend back the locking tabs and nuts, pull the top plate and polish up the weights so it’s all nice and clean and lubricated.
Mike
Dragsix the Dist was rebuilt when the engine was machined. So it is good to go. Thanks for the suggestion.
Brian Moore
