4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#144339 09/24/2005 2:24 PM
This seems so elementary that asking it is embarrassing, but here goes. I don't know how to put a motor on an engine stand. If I take everything off the engine the bolts I would use to fasten it to the stand seem much too small. Is it the normal procedure to leave the bell housing on the motor and them fasten that to the stand? Again, thanks for the help. Allen
#144340 09/24/2005 2:33 PM
Moderator
Moderator
The bell housing has to come off. The engine block attaches to the engine stand. (Assuming there is generally one type of stand and it is like the two I own.)
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#144341 09/24/2005 4:02 PM
All the engine stands i've ever owned had this "X" looking thing that got bolted right to the back of the block.
#144342 09/24/2005 4:30 PM
Both of mine have the four adjustable "X" arms. I use grade 8 bolts and washers to hold the block in place.
1954 GMC De Luxe COE
#144343 09/24/2005 7:02 PM
Be sure to get as much thread into the block as you can.
Keith
If it were easy they'd have grade schoolers doing it!
#144344 09/24/2005 8:30 PM
Quote
No doubt! Using the "two threds in" method would be a recipe for some squashed toes and a flat oil pan!
#144345 09/24/2005 8:48 PM
Riding in the Passing Lane
The old stovebolt 6,s are hard to put on my engine srand. I had to make a bracket to extend the arm over to the block.
1972 Chevy c10 Cheyenne Super
#144346 09/25/2005 4:01 AM
Mine fell off and actually landed smack down on the oil pan and stayed standing upright. Now I need a new oil pan and who knows what else..........Darn glad my feet were not under it! Since then I took a moving cart and shored it up and the engine sits on that now until I get my frame finished enough to put it back in it.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#144347 09/25/2005 8:24 AM
Junior Member
Junior Member
Just get some good grade 8 bolts that will go throught the engine stand,and have enough threads to go into the block at least as far as the bellhousing bolts did.Have a few washers on hand as well,just in case you need to make up a difference in distance between the block and stand.
#144348 09/26/2005 4:06 AM
I didn't like how the long six cylinder block wobbled on the stand Dad made, which has at least twice as much iron as the commercially available stands I have seen recently.
I revamped the brackets and the engine sits on the stand sideways. I'll take some pics and post them if there is interest.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#144349 09/26/2005 4:27 AM
Junior Member
Junior Member
And remember...center the engine on the stand so its not top heavy, otherwise, when you go to flip it over....
Not that Ive ever done that....honest.
#144350 09/26/2005 1:07 PM
Thanks guys. I finally figured it out. Like most things, once you know how it works it seems so simple you wonder why you didn't see it to begin with. Allen
#144351 09/27/2005 10:13 AM
Tim;
You're lucky yours messed up the oil pan;I used the "heavy duty Grade 5" bolts that came with my stand (used) and found my 348 face down the next morning,with a broken crank. Not a good thing. Now I use grade eight bolts,longer than I need,then I stack washers under the head of each bolt until there's just enough threads to tighten before bottoming out. Yeah,it's overkill,but I don't mind,considering the alternatives. I also drilled a hole in the plate to enable me to install a pilot bushing with the engine on the stand,just so I won't forget it once I get the engine on the hook again.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#144352 09/27/2005 10:15 AM
Tim;
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
#144353 09/28/2005 3:51 AM
Quote
Originally posted by speed:
Tim;
I still have that fear because it looks like the first point of contact was the front pulley. It does still turn nicely by hand though. I think I'll just puke if it is worse than just the pan. As you can see if you look close, I had it pretty much ready to go. [img]http://www.sheridanzone.com/images/46chevy/engine.jpg[/img]
Tim Sheridan
