3 members (Hotrod Lincoln, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Sir Searchalot
Sir Searchalot
Using playing cards. Quick trick? nono nono dang ohwell computerdeath
Ha, NICE. Good idea!
1965 c-10 4 wheel drive conversion
Pix in the Gallery Forum
I did that once. Boy, was gandma mad on pinochle night!
Nice tip Bartamos!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
....back in my poor days (ha) I use to rub the tire with a little GOJO from the local filling station.....also used it for cleaning white walls on my '56 coupe. Wow, those were the days.
Sir Searchalot
Sir Searchalot
To be honest, I got that from the internet. I tried it a few days ago and have decided to go back to tape around the edge of wheel and finish with newspaper. Anybody want to buy half a deck of cards?
Original post edited. I say poop on this idea.
Carl, Gramma doesn't know yet. What is worse is that is my wife.
I got Eastwood masking rings back in the last century and have had good results with them. I don't think Eastwood carries them anymore but they are out there.
wheel paint masking rings
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Sir Searchalot
Sir Searchalot
Looking at that gave me another idea. How about using one of my extra slats from vertical blinds?...or chain link fence slats. I'm on a roll.
Bartamos, I think your playing card trick would work better than that Eastwood gizmo. Getting paint on the outer part of the rim nearest the tire would be really impossible. Vertical blind slats with a curve in them would probably work better than the Eastwood thingy. One thing I've used is a hand-held masking device, but not on wheels. I just move it along as I paint. It would have to be custom cut to match the radius of the wheel.
Or you could reinvent the wheel. Take the tire off of it...
I've seen a different picture of the playing card setup online, except they were oriented 90 degrees from your picture, they overlapped each other, and they weren't taped down.
I have not tried it myself. I used 52Carl's trick (above) when I painted my wheels.
Sir Searchalot
Sir Searchalot
Update for those who don't have a tire machine or want to spend the time and money to have tires removed. (us cheapos). It does work. This is my stab at it. No taping, no untaping. Took about 30 seconds per wheel. This is a rattle can job for the back of wheel. Everybody has an old deck of cards in that one drawer.
Please note: The title of my post has always been "with tires". That is the subessence of the trick/tip.
I LIKE IT! A new addition to my bag of tricks, just gotta figure out how to sand and prep with a similar amount of effort/time.
RonR
RonR
1970 340 Duster
1964 CJ5
What is the general consensus for cleaning the inside of wheels. I got the outside polished well, but the inside looks horrible.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
The few times I've needed to clean inside the wheel, a wire wheel on an angle head grinder did the trick. You'll need a twisted knot wire wheel, not a cup brush.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
