8 members (1955 1 Series, Steelonsteel, 55shaker, GRNHydra, 51sub, Wally / Montana, Peggy M, Hotrod Lincoln),
81
Mod | | | Forums66 Topics128,141 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | 1955 Chevy 4400 1st series... I need some brake shoe return springs... These are for the trucks with the 15" x 4" rear brakes (1.5 & 2 ton), two wheel cyls per wheel, that were used from 1953-1960 (?). There are two return springs on each shoe: a green one and a black one... I need two of the black ones. If anyone has new or used ( but serviceable)springs, please give a yell... I just finished rebuilding the entire braking system, but found a broken spring in the right rear drum... Thanks for your help ! Frank 54
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Thanks for the link and suggstion; this is the hold-down hardware for the regular pick-ups...
I need the brake-shoe pull-back springs for the BIG trucks on 20 " rubber...
Anybody out there with a parts truck ?
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | had a feeling it was the wrong stuff... well, good luck with what ya need | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You can try conatcting Jim Carter or someone like that. They always say that if you don't see it in their catalog, give them a call. Other places like Chevy Duty might help you. Also, if you go on the VCCA site and leave a post in the Parts Wanted, you will probably get a response. Also I would think that Mother trucker would have some used ones. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wouldn't a big truck or a fleet repair shop have something you could use? Scott | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | I think even napa would have them...??? or could get them....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i didnt need rear springs when i did my 350 gmc. i needed front ones and napa did have them. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My BIG truck parts store had everything but the drums for both my '56 8400 & 57 10500. They had some stuff on the shelf and had the rest in a day or two (return springs, cylinders, axle seals, shoes, adjusters etc.). Mike  | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Tried two of the local big truck stores (both have been around longer than me - 38 years), they took the spring and tried to match...no go.
Tried ordering a set of springs that were listed for Euclid truck with Wagner 15 x 4 brakes, but the wire was WAY too heavy...
I'm still lookin'...
Anbody got a '52-'60 1.5 or 2 ton that they're parting out ?
| | | | | Joined: Aug 2004 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 86 | NAPA was able to order rear brake springs for my '58 2.5 ton
Matt
"Brunhilde II" '59 Viking 60 To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
| | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Jumpin' Jack...
Check yer' e-mail !
"Desperate" ? Well, that might be an appropriate adjective when only one little confounded spring stands between you and gettin' the Bolt back on its feet !
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Did you try that Napa number I e-mailed to you? George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | George,
So far that's been a no-go with two of the local NAPA stores... (they don't seem overly-motivated to check into it either...)
Will keep trying...
| | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Frank, I have had the same problem with parts clerks. Most of them will not take the time and trouble to help find a part if it doesn't just jump up on their coumputer. Almost any part is available if you can find someone who will take the time to look for it. Try to find some one who has been in business for a long time and has kept his old part books. Usually if you can find some one who has a collection of old dirty books under the counter, he can find the part number and then begin to try to interchange it. I have been luck enough to find two places like that, one is a NAPA store, and the other is a CarQuest location that has a machine shop. The shop foreman has been at it for a long time, and is willing to take the time to look for things. Another place I have found parts is at a local hardware store that carries a very large selection of mechanical items. They have a section that handles bearings and seals, etc., and can often find other old unusual items. Have you done a search of Junk Yards? I have been lucky with that in the past. I found one on the internet that had a number of parts for a 6400 I am working on. I don't have the name at hand but will try to find it and send it to you in another post. Sorry this got so long, I seem to ramble. I guess old age is really setting in. Good Luck Allen | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I found an invoice from East West Auto Parts Inc, of 4605 Dawson Road, Tulsa OK. Phone 918 832 7077 or 800 447 2886. I know he had some old chevys in his yard several months ago, because I bought a vent glass section from him. I had no complaints at all. I believe he is honest. He has a web site at WWW.eastwestautoparts.com, and e mail at [email protected]. I don't know if he had any large trucks, because the vent glass could have come from a smaller one. I found him by going to GOOGLE and typing in junk yards. A bunch of search services came up. They all claimed to be connected with a large number of yards, and would send the request to all of them. If anyone had the part they would contact me. I don't remember which one I used. This fellow was the only one who replied. You might give him a try. Allen. PS: I know of a local small yard that I am sure has some old chevys still around, but I don't know if any of them are large trucks. I will check, and if he has anything, I will let you know. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Frank54, Have you given Jeff McCoy at Bowtie Bits a call? They have lots of used items for big bolts. Toll free- 1.888.838.6887
Stuart. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Frank sent email with pics. mike j | | |
