3 members (rfs56trk, Gdads51, jmoore), 113 guests, and 4 robots.
Topics128,087
Posts1,056,375
Members48,442
#144086 08/27/2005 5:28 PM
Will the manifolds from an earlier 235 engine with babbit bearings fit on a later model with the insert bearings. I have a 235 motor from the very late 50s or very early 60s but no manifolds. I know where several manifolds are available, but they are all from 53 or earlier model trucks. All these trucks were either
1 1/2 ton or 2 ton trucks. Thanks. Allen
#144087 08/27/2005 7:17 PM
Since the aftermarket manifolds are advertised as fitting 216-261 engines, I would assume the the earlier manifolds would work by leaving out the inserts, but I haven't tried it.
Baldy
#144088 08/27/2005 9:15 PM
Didn't someone just ask this the other day? Try the search feature and see if you can find the post. I seem to recall something about the alignment rings...??
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
