| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Got an exhaust manifold laying around, though it fit a 235 / 261. Outlet is angled back, seems to be the same as others I have except that it won't bolt to the intakes I have. This one has inner bolts that attach it to the intake spaced 2.50" apart, all the others I have are about 2.12" spacing. Cast # is 8836388.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 |
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | I thought GMC all went straight down.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If you have either 216 or 235 intake laying around, you will be able to see which one does or does not mate up to the exhaust. Also 216 intakes are straight, 235s look like a gorilla twisted them. The 216 manifold intake alignment sleeve measures 1 13/32" OD by 3/8" HIGH, 235 sleeve is 1 17/32". So find either intake to determine what you've got for an exhaust. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Have 3 intake off 235 / 261, none mate to it. Exhaust ports all line up w/ other 235 / 261 exhaust manifolds I have. This odd one also has the firing order cast into the front runner which the others don't.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Not all 216 manifolds dump straight down. Starting in 1949, with the redesigned steering design for the passenger car, Chevrolet angled the dump at an angle backwards. Just so they only had to make one design, they used this same angled manifold on trucks until 1953.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | So perhaps the '49 - -53 intakes have the wider bolt spacing on the inboard bolts attaching it to the exhaust? All the stuff is '58 & later.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | Does it have a two bolt or three bolt flange where the exhaust pipe bolts on? | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Does it have a two bolt or three bolt flange where the exhaust pipe bolts on? 2 bolt flange, yes it is 3835388 on closer inspection. It's been split for dual outlet w/ functioning heat valve. Bought it a few years back. supposed to fit 235. Oh well, at least I know what I have.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | So perhaps the '49 - -53 intakes have the wider bolt spacing on the inboard bolts attaching it to the exhaust? Just for future searches, the bolt spacing is the same on all 216’s and 1941-49 truck 235’s, which use the same manifold as the 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Does this apply to both car & truck engines? Once again, thanks for all the help!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Sorry, I left out the word truck above. Now edited.
