1 members (Barnfind49), 135 guests, and 2 robots.
Topics128,225
Posts1,057,784
Members48,477
Page 1 of 2 1 2
8
nothing beats a try but a failure
8 Offline
I will begin to show how everything went. The first thing I did was build a she shed on to the side of my old shed. I pulled the cab off and then I removed the motor.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
That's pretty awesome! Keeps us in the loop.
Ron - - Dusty53
1954 Chevy 3604
8
8 Offline
The engine was taken to my favorite machine shop. Cleaned and bored 30 over.
8
8 Offline
Next thing we did was under size the crank by 10 thousand. It then was balanced. Conditioned the rods.
8
8 Offline
I installed the mains. I measured each main and shimmed accordingly. Note: Get your own paper and build your own shims.
87GN , I have a question or two regarding the engine rebuild at the machine shop. Is/was it an option to have the block line bored for the mains and grinding the crank to eliminate the shims on the main caps? Similar question on grinding the rod journals on the crank , boring the rods to eliminate the shims? Thanks for sharing your progress.
Ron
Ron - - Dusty53
1954 Chevy 3604
Crusing in the Passing Lane
Now is a good time to bore the block for a modern rear main seal.
Ed
8
8 Offline
Dusty53, good question, to line bore the mains on this engine would be alot less work if you compare it to the time spent adjusting the shims to achieve a match between the crank and the mains. If you line bore the mains a center line would have to be agreed on and then each bearing would have to be adjusted to accommodate the new diameter. Remember always shoot for the moon if you miss you land in the stars. There is a passion that drives me to achieve the things that are greater me. Hopfully these montras will help support my reasons for the seamingly endless attention to details. To the rod question, 10 thousand under rod bearings were purchased. We then installed them into the rods. Having previosly marked the side of the rods days before we measured each rod diameter with the bearings in. If they were within spec great if not the rod bearing was then conditioned. All the rods were conditioned.
8
8 Offline
Hello EdPruss, I installed #6100 from best gasket. Installed accordingly your sealing power is greater then what came in my engine gasket kit.
87GN,
I got Best gasket sets for my spare 302s.
Ed
Thanks for the feedback. If I end up doing any rebuilding I doubt that I will do anything other than follow the Shop manual. I wanted to understand more about the options and you answered my questions. You know, its hard for me to get past the fact that these old engines just "keep going" and that although the methods for repair have been changed greatly by advances in machining and technology, the old methods produced some pretty solid results. I'll be following your progress and thanks again.
Ron
Ron - - Dusty53
1954 Chevy 3604
8
8 Offline
While the block and the head were being milled I started to rebuild the distributor.
8
8 Offline
After milling was complete we washed both the block and head. Note finding a head that was'nt cracked was expensive. We got the new cam and bearings in and installed the crank along with the timing cover. I was able to purchase a NOS locking clip for those two special bolts, you know the ones that bolt inside out and hold the bottom of the timing cover.
Why didn't you mod the timing cover bolt arrangement to work from the outside? Or is that a GMC only thing?
8
8 Offline
I didn’t consider that option. How would that work?
I know where to get the instructions on OldGMCtrucks forum, but you have to join to access the info. Instructions are likely available elsewhere, probably even here on Stovebolt if I knew where to look. Maybe someone who knows his way around the site can point us at it?? User name SlimSix posted the instructions on the GMC site. I know him from the GMC site and have just PM'd him asking for the instructions.
I re-read the instructions and the thread implies that same info works for Chevy 6s of the period. Should work because these front of the engine parts interchange between Chevy and GMC.
I could copy the instructions and e-mail them if we can't find them here.
Stovebolt Tech Tips. Go to the Tech Tip Engine section and scroll down to almost the bottom of Engine Tech Tips. You will find the instructions there. Good luck.
Sweet's instructions are good, but the instructions that SlimSix posted are done with the engine removed and are more appropriate for 87GN's project.
8
8 Offline
Tech tips are great, The engine is near completion just a few more bolt on's. The timing cover mod is pretty slick. Thanks you guys.
8
8 Offline
Once the crank and cam were in it was time for the head to go on. Earlier I mentioned It was hard to find a good head. The original head was cracked in the combustion chamber. Check out the pictures.
8
8 Offline
I purchased a head from someone I did not know. Had it shipped to my house in Maryland. It was cracked.
8
8 Offline
My wife and I are retired and injoy road trips. We hadn’t been to New England yet so we loaded up the truck an headed north. Between the road trip north and my bout with the purchased head dubacal, I was still looking for a uncracked head. My internet search lead me to Chevy Supply of Assonet Massachussets. I called to ask if he had a good head he said yes I do. Well, you know what that means, Donna and I have added a stop to are New England ride. Long story short we meet the owner and he and some of his stovebolter's were picnicing by his large shop. He and I became good friends right away. He and some of his friends showed me around his coral of rare american classic's. He did show me 3 heads that were on a shelf with many other parts and he politly said to pick one. Whow, I was floating on air almost geety. I picked my head and he and I pulled it from the shelf. Mean while I saw a oil pan in much better shape than mine. Yes was all he said. Donna and I left with a smile on our faces. I knew why I was happy but I don't think Donna knew why she was smiling. Attached you will see a picture were I am shaving the outside diameter of the valve guide to accomodate the new seals.
8
8 Offline
Finished the valve seals got the new oil filter system installed and brought her home.
8
8 Offline
Onto some more restoration. The steering box.
8
8 Offline
And along came the rear
8
8 Offline
Can't forget the trans. SM420
8
8 Offline
You will see 2 pictures one will be cleaned starter and generator. The second pictures shows the same parts except for one thing, I am learning to apply black oxide.
8
8 Offline
I have been working on the truck. My next couple of posts will be before and after pictures of the cab floor and all four corners. First 3 will be the cab floor.
That's some really nice metal smithing!
A floor pan from scratch - wow! thumbs_up
~ Dan
1951 Chevy 3 window 3100
8
8 Offline
Driver and passengers front corner
8
8 Offline
Thanks GDads51
Authorized Pest
Authorized Pest
Originally Posted by 87GN
I will begine to show how everything went. The first thing I did was build a she shed on to the side of my old shed. I pulled the cab off and then I removed the motor.
First chance I had to look at your PJ in details. I really like the way you started the whole journey! A "she shed" ... that's very funny! grin
Looks like you are making great progress. thumbs_up
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
87GN (Grand National?), you need to stop this right now. Your craftsmanship and progress are going to give us mere mortals a complex!
Great Work!
RonR
RonR
1970 340 Duster
1964 CJ5
8
8 Offline
Heater before and after
Was it working before disassembly but just rusty?
1950 Chevrolet 3100 (Ol' Roy)
87GN,
That's a lot of detailed clean-up work.
Any helpful tips/hints on what you used to make the work less intimidating???
~ Dan
What Dan said. Chemical or mechanical rust stripping?
BTW, I changed your title a bit to add more information, making it easier for folks to find in a search.
8
8 Offline
A blasting cabinet on everything except the motor. I used a wire wheel on a die grinder for the fan motor. I did take the motor apart to look for damage. None to be found. To clean and inspect the inside of the housing I had to remove the two rivets holding the brush mount plate. To reinstall the plate I used four sheet metal screws and applied a little epoxy on them.
8
8 Offline
Also to Ottos question yes the motor is still working.
Beautiful work, and you are a talented mechanic sir! I’m very envious.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Page 1 of 2 1 2
Moderated by  Phak1
