1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | does anybody know if 22.5 rims will fit on my 46 1 1/2 ton truck? the current tires are shot and the rims are the split type. i am looking to make it a work truck so all options are on the table. | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | You would probably have better luck putting 19.5" wheels on than the 22.5's. The 22.5 wheels are a large 5 bolt pattern I think, Scott | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | homer i could be wrong but as i recall 22.5 should be the equalin dia. to 20 inch wheels but are TUBELESS.as are 22inch equal to 24.5 tubeless | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | A 10.00x22.5 is the same diameter as a 9.00x20 and a 9.00x22.5 is the same as a 8.25x20. The 22.5 are tubless and the 20" are tube type, as stated. I think a 19.5 might fit the fenders better if you can find one to fit your lug pattern. Chevrolet 22.5's are 6 lug. Mike  | | |
