9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible), 243 guests, and 1 robot.
Topics128,095
Posts1,056,075
Members48,433
#144027 08/23/2005 5:46 PM
I
I Offline
I'm not there yet, but I was wondering how much a 8.25 x 20 tire costs... Nothing fancy!
I can't seem to find them online.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#144028 08/23/2005 6:05 PM
I just put a set of 8.25x20's on my 6500 duals. They ran me just below $500. They are biased though. The radials jump up to almost twice as much. Anybody that sells truck tires should be able to order those at least.
#144029 08/23/2005 6:07 PM
I
I Offline
Was that for four tires or all six?
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#144030 08/23/2005 6:26 PM
I purchased 16, new 8.25X20 radials, including tubes, already mounted on rims, from a guy out of Norfolk, Va., at $40 ea. He started out with about 70 tires. I'm not sure how many he has left.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#144031 08/23/2005 6:27 PM
I
I Offline
Spanky,
That's a steal!
Do you have contact info?
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#144032 08/24/2005 4:47 AM
Contact Jeff Floyd at, 1 800 868-2018. The rims, won't be usable. They were special made, for a project application.
Spanky Hardy
1950 GMC 250 1-Ton
#144033 08/30/2005 10:21 PM
I know it's late but that price was for 4 tires.
#144034 09/14/2005 3:44 PM
Inky,
Availability is limited; I got a quote from my local Allen Tire distributor about two years ago:
8.25 x 20 bias were about $120 for highway tread (fronts) and about $150 each for lug (mudgrips)tread for the rear.
I think I saw 7.50 x 20 on the Delta Tire site, but have not contacted a local dealer for pricing.
Also don't know if the 8.25 tire is too wide for the original 5" rims... ???
You can get "correct" 6.00, 6.50, and 7.00 x 20 tires from "antique tire" merchanst like Universal or Coker, but I think the 6.00 x 20 is running about $150 plus shipping.
Tubes run about $20 each...
None of the local tire dealers are stocking 20" bias any more, even though older trucks running them are still a common sight on our roads...
Good luck!
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#144035 09/15/2005 5:42 AM
A construction outfit I used to work for used 9.00X 20 tires on a couple of 65 C-60 dump trucks they had,and they worked,but had very little clearance around the front fenders,bumper corners,and steering linkage,and on the rear they nearly touched when the trucks were empty;I think the only thing that saved them from continuous blowouts was the fact the trucks were never used outside of town-too slow. A set of 8.25's should work fine on the rear,but still might have some clearance problems on the front,depending on your ride height,how the fenders hang,and what type front suspension you have.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#144036 09/18/2005 12:00 AM
Junior Member
Junior Member
Mike Richey
Big 49
