1 members (tclederman), 94 guests, and 4 robots.
Topics128,181
Posts1,057,185
Members48,465
#1439902 02/03/2022 4:24 PM
Is this filler tube correct for a 1940 Chevy truck?
If not what is it for and where can I get a correct one?
Instead of a removable cap, it has a pressed on plug with an “X” pressed into it.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
Rabaut #1439905 02/03/2022 4:43 PM
I believe the road draft tube for the 1940 engine had a removable cap at the top for adding oil. If you use that tube, you'll also need to install a valve cover with an oil fill cap on it from a later model engine.
Drop me a PM- - - -I might be able to help with the correct draft tube.
Rabaut #1440023 02/04/2022 2:06 PM
That's the road draft tube not an oil filler tube. Fill the oil through the cap on the front of the valve cover.
1950 Chevrolet 3100 (Ol' Roy)
Rabaut #1440034 02/04/2022 2:59 PM
HRL is correct on that though. There ARE draft tubes that have a screw type filler cap on them. I have one. The purpose of the filler cap? Can't say.
Thinking about it though, I suppose you could fill oil through this type draft tube. Wouldn't it make a mess though? Some of the oil would go straight through, would it not?
Mike
1951 3100 5 window
Rabaut #1440040 02/04/2022 3:40 PM
I have one of those tubes that will be headed to the OP soon. It is correct for the truck he is working on, since his valve cover does not have a filler cap. No, oil will NOT leak out of the draft tube- - - -it's baffled to prevent that from happening.
Rabaut #1440043 02/04/2022 3:47 PM
L Online: Content
What Jerry is describing is exactly what I have on my '37. The valve cover has no fill cap. You add oil via the road draft tube, and no, you don't get oil leakage.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Rabaut #1440065 02/04/2022 6:16 PM
Here's the cap for late 30s-40s road draft tube, later version had no cap, added oil via cap on valve cover.
for some reason can't upload photo?
1946 1/2-Ton Chevy
