2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#143815 08/09/2005 12:12 AM
Junior Member
Junior Member
I have a 1945 chevy 1.5 ton and I'm trying to figure out if it has a 216 or an early 235 in it. The block number is BG712427, Does anyone no how to determine what it is?
Thanks in advance,
dcolella
Dcolella
#143816 08/09/2005 12:28 AM
I
I Offline
Do you have a casting number? It should be on the side of the block just below the side cover under the 1&2 plugs.
Based on bg it appears that it would be a 235 from this page.
235 casting numbers
#143817 08/09/2005 1:02 AM
Junior Member
Junior Member
Thanks for your reply im4racin. The casting number is 712427 which had the prefix BG.
I couldn't find the cast number listed anywhere. Did they have the BG prefix on 216's?
Dcolella
#143818 08/09/2005 3:32 AM
I
I Offline
is that number stamped or cast? the number seems to be a serial number, a casting number will be raised from the side of the block
rh
#143819 08/09/2005 7:15 AM
X
X Offline
BG is the prefix for the RPO 235 used in the conventional heavy duty trucks (1.5 ton) in '42-'45. 712427 would be the engine build sequence number.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#143820 08/09/2005 5:57 PM
According to the casting number information at the inliners.org website, the BG prefix was used on 235 engines in both '42 and '46 ('43 thru '45 isnt listed on their chart)
#143821 08/09/2005 6:27 PM
X
X Offline
Most references (even Chevy literature) don't show much for the years '43-'45 because of the war restrictions during those years (civilian trucks weren't built, except by special allowance). There was a small amount of civilian production that started back up in '45. I think it's safe to assume that the '42 engine prefixes carried through those years. And I should have included '46. That's '46 first design, or interim series. '46 second design was a new series with new truck ID and engine number prefixes.
Curt
#143822 08/09/2005 9:42 PM
I found the numbers '235' stamped on the side of the pan (it's different than the 216 due to longer stoke) after I spent hours searching the numbers.
1946 1/2-Ton Chevy
#143823 08/10/2005 2:52 AM
Junior Member
Junior Member
Thank you all for your replies... Yes the number I provided is stamped in the right side of the block near the distributer. I guess it's safe to assume this is a 235, I will check the side of the pan for any signs.
Thanks again,
DColella
Dcolella
