| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Ok, so I was under the truck this morning and I got to looking at my tranny. Now keep in mind, i've had this tranny out twice now, and while i've seen this thing hangin' out of the tranny before, it never really looked PTO-esque untill today. So have a look at the picture.. [img] http://www.oldtruckstuff.com/chevy/ptohh.gif[/img] That thing closest to the tranny feels like it outta turn.. that thing sticking out beside it on the outside how you engage it?
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Correct on both counts. This looks like an old Spicer PTO and it is made for a lever shift i.e., NOT a cable shift. If it isn't free turning then it is in gear and engaged. You can remove it if not needed and put the 6 bolt steel cover and gasket back in it's place. You can get one anyplace that installs or sells PTO's. I see your in western NE so call Kois Brothers or Frontier Truck, both in Denver. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm going to keep it. I have a stakebed dump I want to put on this truck, and untill today thought I was going to have to find a PTO.
How would the PTO engage? Seems like pulling or pushing that deal with the hole it it outta do it, right?
| | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | correct that should engage or diengage the pto but for a dump bed you will probally need a hydraulic pump and valve tank and lines
rh | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The dump bed I have came off an old stude, and has pump, tank, lines, cylinders.. just have to bolt up the pump to match up with the PTO in this truck and i'm gunna be a dumpin' fool.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Be sure to use universal joints on both ends of the pump drive shaft, and make the crossmember that supports the pump plenty strong! A simple piece of flat bar pivoted in the middle, and attached to a piece of round stock with clevises on both ends is all you'll need to engage/disengage the PTO. Run it through the floorboards near the parking brake, with another handle to the hydraulic valve for the dump bed. Jerry
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | As I said Fumblin, it is a lever shift so you will need to make or come up with a floor mounted lever to push/pull on the shift rod. | | |
