0 members (), 48 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#143714 08/02/2005 3:16 PM
Ok, so I was under the truck this morning and I got to looking at my tranny.
Now keep in mind, i've had this tranny out twice now, and while i've seen this thing hangin' out of the tranny before, it never really looked PTO-esque untill today.
So have a look at the picture..
[img]http://www.oldtruckstuff.com/chevy/ptohh.gif[/img]
That thing closest to the tranny feels like it outta turn.. that thing sticking out beside it on the outside how you engage it?
#143715 08/02/2005 4:50 PM
Correct on both counts. This looks like an old Spicer PTO and it is made for a lever shift i.e., NOT a cable shift. If it isn't free turning then it is in gear and engaged. You can remove it if not needed and put the 6 bolt steel cover and gasket back in it's place. You can get one anyplace that installs or sells PTO's. I see your in western NE so call Kois Brothers or Frontier Truck, both in Denver.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#143716 08/02/2005 4:57 PM
I'm going to keep it. I have a stakebed dump I want to put on this truck, and untill today thought I was going to have to find a PTO.
How would the PTO engage? Seems like pulling or pushing that deal with the hole it it outta do it, right?
#143717 08/02/2005 6:45 PM
I
I Offline
correct that should engage or diengage the pto but for a dump bed you will probally need a hydraulic pump and valve tank and lines
rh
#143718 08/02/2005 8:18 PM
The dump bed I have came off an old stude, and has pump, tank, lines, cylinders.. just have to bolt up the pump to match up with the PTO in this truck and i'm gunna be a dumpin' fool.
#143719 08/02/2005 8:37 PM
H Online: Content
Be sure to use universal joints on both ends of the pump drive shaft, and make the crossmember that supports the pump plenty strong! A simple piece of flat bar pivoted in the middle, and attached to a piece of round stock with clevises on both ends is all you'll need to engage/disengage the PTO. Run it through the floorboards near the parking brake, with another handle to the hydraulic valve for the dump bed.
#143720 08/03/2005 12:34 AM
As I said Fumblin, it is a lever shift so you will need to make or come up with a floor mounted lever to push/pull on the shift rod.
Dave
