Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (ShopRag, farmallb, jasrking, TUTS 59), 34 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#1435589 01/01/2022 9:17 PM
Crusing in the Passing Lane
Work has slowed down for a few days!
Ed
EdPruss #1435676 01/02/2022 4:34 AM
We're pretty cold here right now, but no snow.
Is that blue Binder a KB-5?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
EdPruss #1435707 01/02/2022 2:23 PM
Yes, 345, IHC 5 speed, D-70 rear axle.
Ed
EdPruss #1435741 01/02/2022 5:55 PM
How far did you whittle down the wheelbase and bed on that 530? That trip to KC was quite a ride!
EdPruss #1435817 01/03/2022 3:28 AM
Jerry,
I shortened about 4’, as much as I could with the existing running gear and crossmembers. Just right for the crane bed I had on another truck. Made a stepped welded joint, long bolted doubler. Worked out well that length. Easy one man job, although the mag drill would have been easier with 2.
Besides it was awkward getting and out my driveway.
Ed
EdPruss #1436670 01/09/2022 2:55 PM
Ed Pruss I see on a lot of frame welds they make all kinds of fancy cuts to get the job done,I assume you welded with 7018. On big fertilizer off road frames we always cut them with thin wheels,scratched up clean tacked-up straight welded with 7018 lo-hi or what the pipe-fitters called hippie-rod. That was because when 7018 showed up those hippie fitters could make an x-ray quality weld with it !! Even girls done it.
EdPruss #1436733 01/09/2022 10:18 PM
fixite7,
Yes used 7018 and flanged bolts and nuts, much easier.
Ed
