6 members (Rusted Nut, Lightholder's Dad, Bill Hanlon, Hotrod Lincoln, Buckeye998, 1 invisible), 87 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
#143564 07/24/2005 8:54 PM
Junior Member
Junior Member
Does anyone know what the timing should be set at for this motor with HEI? Between the timing, the carb, and the truck running hot, I can't figure it out. Thanks, Jeff
#143565 07/24/2005 9:24 PM
2 degrees before it starts to ping, under a load. I don't think the timing and a lean burn is your problem. I would look at a plugged radiator or a stuck or missing thermostat being the culprit. Borrow a digital thermometer and start looking for cool spots in your cooling system. I did see one far out scenario one time, a waterpump had rusted the impeller fins completely off of the pump, not moving any water at all. That one sucked to diagnose. Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#143566 07/25/2005 11:49 AM
Junior Member
Junior Member
Thats what I don't understand. The whole cooling system is new from rad to all hoses and water pump. I am not running a thermostat. I can't think of nothing else.
#143567 07/25/2005 4:04 PM
You need to have a thermostat to cool properly. The thermostat slows the coolant as it passes through the radiator giving it time to transfer heat to the air. Otherwise the coolant passes through the radiator so fast it doesn't have time for the radiator to do its work.
