3 members (Samantha, Otto Skorzeny, tesa), 337 guests, and 4 robots.
Topics128,162
Posts1,057,057
Members48,463
Junior Member
Junior Member
Hi all I'm wanting to make my 66 C60 into a retro car hauler.
I'm looking for any info on dovetail or roll back plans ideas and so on.
I suppose I could go buy a new one but I'm low budget and have a good bit of the steel to start,and can do the work myself.
I'm leaning toward the dovetail just for the simplicity.
Might be interested in a used bed for low bucks and close to SC.
Any help would be greatly appreciated.
Jim
Jims Webshots page
Jimmy
Flat bed not too hard. 5" channel for two main runners, mount on 1" wood decking, cut down middle and drill holes for each rivet to set in. Use 4" channel all around outside, miter if you can at corners. Use 3" channel for cross braces if using wood for bed, or use more 4" to make level for sheet steel. Use rect tube for stake pockets, and run a wide 3/8" thick or so flat stock on outside of those for tie downs for straps. Old U=bolts with each length down opposite sides of a cross'channel makes good tie downs. OR, put them over the main 5" rails and stick above floor. Angle the bed after the frame ends, by cutting the metals at proper angle. Some needs cut off both mating ends, or it won't line up correct to weld if you cut just one. Some ideas I have done. For wood I like 2 x 6 tongue and grooove, or random size 2 x lumber and cut the dado in each edge. This is so dirt and gravel won't fall thru when hauling, as wood always shrinks if you use treated. Non=treated will rot in year or two. Never found a good paint or finish to stay on in weather or against wear. Best I used was Farm Horse Pen Paint, black. Kind of the modern Creosote replacement.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
I found this one and the truck doesn't look too bad either,
Scott
http://www.tommystrailers.com/bertha.htm
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
