2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
I rewired my 55 t bird ( with help) and am feeling froggy. How hard is it to rewire my c10? The wires are worn and have been altered many times, under the dash looks more like cob webs than wiring. I carry a fire extinguisher which may show my confidence level with it.
I think I can get the " painless " harnesses. Is this something a amateur like me could tackle? I've had the guage display out before and replaced face did not look to complicated.
It runs as is but it seems to be begging for attention.
Thoughts?
1964 Stepside C10
"Well we didn't get all dressed up for nothing." ~ Braveheart
Yes, a novice can install a painless harness.
I would recommend a Speedway Motors harness instead though. Similar quality and much less expensive.
Just take your time. The wires are labelled. You will need to terminate them, but as long as you are comfortable crimping or soldering ends you should be just fine.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Sir Searchalot
Sir Searchalot
PM sent
I'd highly recommend the American Autowire Classic Update kit. I'd also recommend a very affordable crimping tool that really makes life easy.
I wish I had that when I did my thunderbird
1964 Stepside C10
Have you used any of the crimps with solder a sleeves that just require heat?
I'm getting ready to install the new dash after Christmas.
dj durant
More pix on Flickr
I got a set of those crimps with the low temp solder that melts when you shrink the tubing. Are those the ones you are talking about?
If so, I was not impressed. There was not enough solder in the joints to really wet the wires and make a good connection. I would not say they are any better than regular crimps.
G.M. uses them for many service splices. They are known as Duraseal splice, has a glue that makes a seal to the wire insulation.
The cheap ones are just that.
BC
1960 C60 pasture art
I bought the cheaper universal painless wiring for my 64 c10 but after looking at them I decided to return that one and get the more complete and expensive one with plugs.
I'll let you guys know how it turns out
1964 Stepside C10
