Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1434354 12/22/2021 5:07 AM
I have to replace the headlight switch on my 50. The original has 7 wires and the universal replacement switch has 6. So I was wondering if one of you guys has picture or diagram on how the non original switch wires up. I haven’t bought one yet , just going by the pictures online. Both are 6 volt.
1950 4400
Ex Hall Monitor
Ex Hall Monitor
back yard wrench turner
Joe, I followed the instructions on the link above. I was able to make my switch function like new again.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderator, Electrical Bay
Thanks Tiny, Wayne. I've been hoping that and some of the other things I've provided might become Tech Tips, but it seems that section is in slumber mode. Tiny, maybe you can help there?
~ Jon
I also followed the post by Jon G and have revived 3 switches to like new condition thanks Jon G.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Thanks Jon for the information, I think I can salvage mine with the info you provided.
The parking light leg is broken off mine but I don’t see any reason why I can’t put that wire on the tail light leg, other than that all I have to do is clean up switch and grease it like you said.
1950 4400
Ex Hall Monitor
Ex Hall Monitor
Sorry Jon. I'm no longer a Mod. You'll need to contact John or Peg.
Putting the parking light wire on the tail light connector will make the parking lights stay on with the headlights. Lots of newer vehicles do that, so there shouldn't be a problem doing it that way. Does the universal switch have the dash light dimmer and the dome light ground built in?
I don’t have one yet. I’m trying to fix the old and I got a line on a used one here locally but I haven’t been able to go check it out.
1950 4400
Joe Alan If you get that used one you might take a can of WD40 remove the knob,press on that cone shaped spring button and pull the knob out. Gotta do that to get it out of the truck ! Put the tube on your WD 40 as deep as it will go in the switch,spray and pull it out to lube the dry switch. Don't think WD will hurt the switch,sure frees them up .
