| | | Forums66 Topics128,004 Posts1,055,250 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | I have to replace the headlight switch on my 50. The original has 7 wires and the universal replacement switch has 6. So I was wondering if one of you guys has picture or diagram on how the non original switch wires up. I haven’t bought one yet , just going by the pictures online. Both are 6 volt.
1950 4400
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Joe, I followed the instructions on the link above. I was able to make my switch function like new again. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2014 Posts: 4,475 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,475 | Thanks Tiny, Wayne. I've been hoping that and some of the other things I've provided might become Tech Tips, but it seems that section is in slumber mode. Tiny, maybe you can help there?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | I also followed the post by Jon G and have revived 3 switches to like new condition thanks Jon G. | | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Thanks Jon for the information, I think I can salvage mine with the info you provided. The parking light leg is broken off mine but I don’t see any reason why I can’t put that wire on the tail light leg, other than that all I have to do is clean up switch and grease it like you said.
1950 4400
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tiny, maybe you can help there? Sorry Jon. I'm no longer a Mod. You'll need to contact John or Peg.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Putting the parking light wire on the tail light connector will make the parking lights stay on with the headlights. Lots of newer vehicles do that, so there shouldn't be a problem doing it that way. Does the universal switch have the dash light dimmer and the dome light ground built in? Jerry
| | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | I don’t have one yet. I’m trying to fix the old and I got a line on a used one here locally but I haven’t been able to go check it out.
1950 4400
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Joe Alan If you get that used one you might take a can of WD40 remove the knob,press on that cone shaped spring button and pull the knob out. Gotta do that to get it out of the truck ! Put the tube on your WD 40 as deep as it will go in the switch,spray and pull it out to lube the dry switch. Don't think WD will hurt the switch,sure frees them up . | | |
