5 members (Tstan7, Napco Mark, Gone, ShopRag, Mike Roache), 68 guests, and 5 robots.
Topics128,022
Posts1,055,353
Members48,420
#14331 04/18/2004 8:26 PM
I have aquired a set of NOS pistons for my 270 GMC rebuild and they are all coated with what I think is called "cosmolene". It is sort of a wax based protectant that each piston has been dipped in to preserve it. Anybody got a reall good method for removing this stuff? Someone had partially cleaned one of the pistons and I finished it up with some Naptha and a tooth brush. It took quite a while to get it clean. There must be something else I can use. What say you????
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
#14332 04/18/2004 11:15 PM
Take them to a shop that has a hot water parts washer. The solvent in the water and the heat should clean them right up.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#14333 04/19/2004 6:24 PM
Diesel fuel or Kerosene works well on cosmolene. Don't use gasoline.
Paint & Body Shop moderator
#14334 04/20/2004 5:05 AM
I'll try the kerosene. I think I have some around here somewhere. Maybe out in the shed. Thanks
#14335 04/20/2004 5:21 AM
Solvent or brake cleaner will work. Let it soak and wipe off. repeat if neccessary smile
