7 members (DuckRancher, 55shaker, TexasA&M48Truck, 1955 1 Series, sron48, Doug Boudreaux, 1 invisible), 77 guests, and 3 robots.
Topics128,200
Posts1,057,405
Members48,471
I would like to add wooden planks on the side of the bed. But how you fix the vertical ones on the bed? I have no holes orso to fix them though. If i stick one in from the top if falls out in the bottom 😁
Who has a picture where i can see the inside of the bed and how its fixed?
Crusty Old Sarge
Crusty Old Sarge
Normally the vertical slats drop into the bed pockets at the corners.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
AD Addict & Tinkerer
The horizontal slats keep the upright posts (slats) from falling thru.
Phil
Project Journals
Stovebolt Gallery Forum
Aaah ok. I was wondering indeed. Because if you put a vertical slat in the come out at the bottom haha
So the horizontal planks will rest on the side of the bed?
Robby I also made a wooden rack on the sides. For the sides i used wood slightly bigger than the hole itself, after that I shaved a bit of the underside so that it goes in the holes. The wooden beams i used were from the Karwei. If you want i can give you the dimensions and detailed photos of the rack.
1951 Chevy 1300
"Selling trees in the Netherlands"
Follow along in the DITY Gallery
Thanks. Will do that! Did you use a special kind of wood?
I don't know what kind of wood it is. It think it is sparrenhout (bouwhout).
1951 Chevy 1300
I just used screws on the inside of the pockets.
The AD trucks came from the factory with sheet metal stops welded in part way down the stake pocket. My bed also had thru holes front to back just above the bottom of the stop.
But the stops in mine had been beaten out by whatever they put in the pockets and there were holes in the aprons below the stake pockets. All that is getting fixed, including new stops that I had fabricated.
The first pic shows one of the stops sitting above where it goes in the stake pocket, and the holes thru both the stake pocket and the stop for a thru-bolt.
The second pic shows my dimension sketch for fabbing new stops. An ex-employee worked for a company that has a 30 ton press brake, and offered to bend them up for me.
Pic #3 is the new stops painted and ready to go in.
I used the same method as Hookalatch, with a countersunk head wood screw in the side of the pocket, then painted it the same colour as the sides. Virtually invisible.
My bed bed rack is made from red oak. I used stainless steel fasteners. Have fun with your project!
I got it done last week. I love the look of it.
