3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
Hi all. I have a completely stock and original 59 3100 2WD steering/suspension set up. It's in need of overhaul, my shoulders are shot, and I've been studying Manual R&P w/coilover IFS. Many concerns. The primary one being that I do not want to lower the front end. I want/need it to sit like a truck. I have checked out several IFS builders, and the only one to date that has said they can truly keep my factory ride height is a place called Scott's Hot Rods, in Knoxville TN. They are way more expensive than other kits, but claim to build ride height to my specs. (Many others have "stock Spindles", but when questioned, all say that it lowers ride height by a minimum of 2-3 inches). Have any of you ever dealt with them before for a reference/review? Do you have other suggestions? I'm hoping to hear from those who have truly taken this path. Thanks and happy Thanksgiving! Grant -n- Debbie.
Crusty Old Sarge
Crusty Old Sarge
You can upgrade your steering sector (steering gear box) and keep your factory springs a original ride height. I am using a kit from Classic Performance Parts (CPP), it uses a 400 steering sector mounted in the factory location. You will need to modify the lower end of your steering column to adapt to the sector and add a power steering pump and hoses. You can add Teflon inserts to your spring pack to help soften up the ride. Check out my posts in the project forum, I took pictures of everything so far, I have not finished the steering linkage yet but you can see how it is mounted. Good luck and Happy Thanksgiving.
https://www.classicindustries.com/product/all-years/chevrolet/truck/parts/5559pskoc.html
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Detroit Eaton springs can build custom springs with softer ride and any ride height you want, add a power steering kit like Craig has going and you will be money ahead and still have the truck you want. What you don't want is R&P steering with a straight axle. If you go with a front end kit, what about the rear axle? It will still be rough riding, with new springs all around, the whole truck will be nicer. Does the kit you are looking at have new brakes? are they compatible with the brake system? Will the wheel bolt pattern match the rears?
Up-grading what you have is a lot easier then replacing in my opinion.
Rebuilding the stock steering and front suspension and adding electronic power steering will probably be simpler and less expensive than doing an IFS conversion. The electric P/S system for a Saturn can be adapted to the original steering worm shaft between the dash and firewall with a little machining and fabrication. Contact "Coilover" for details of the conversion. His shop does it frequently.
Crusing in the Passing Lane
Another option would be to mount a Delphi(Saginaw) unit outside the frame, just behind the bumper. Need to make sure all tapered male and female fittings are compatable, might need to shorten drag link, must be level when loaded, as I did on my GMC 350, 2 ton, with P-3500 HD disc brake spindles.
Ed
That's what I'm talking about! Great information! Thank you. I am investigating these leads. Thanks!
Keep the ideas coming please! How do I contact "Coilover"
He posts here on a regular basis. Click on the envelope icon at the top right of the page and send him a private message. Evan doesn't always notice the flashing icon that tells him he's got a PM so it might be a while before you get a response.
Crusty Old Sarge
Crusty Old Sarge
I had considered using the steering box mounted outside the frame rail. Somethings to think about having to relocate the shocks and fabricating a steering shaft. I also read a lot about the steering geometry and bump steer, with a steering box mounted forward of the axel you change the axis point on the draglink, the springs are fixed mounted at the rear. With the two opposing points of movement bump steer could become an issue. With the steering gear in the factory location both points of movement are at the rear.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
The power steering box from certain models of Toyota Land Cruiser is a virtual clone of the stovebolt steering gear, and can be installed in a very close location to the original box without making major changes to the steering geometry. Of course, a power steering pump will still need to be adapted to the engine.
Hot Rod Lincoln, you have any more info on what vintage of Land Cruiser ro look at for one of those boxes? This is potentially relevant to my interests.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The box mentioned by tuts59 at CPP is a new direct copy of the Land
Cruiser box, should save searching around for a Toyota box.
Ed
