7 members (Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna, klhansen, joe apple), 153 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#143052 06/19/2005 6:53 PM
Junior Member
Junior Member
smile I'm new here and have just acquired a 1966 C60 flatbed 292 4 speed.
I'm looking for basic info such as 1 ton, 2 ton, parts sources and general info sites or books.
Any help would be appreciated.
Jim
Jimmy
#143053 06/20/2005 5:10 PM
Truckman,
Welcome to the Stovebolt site.
I am one of the few on this site with a 1966 C60. They are darn good trucks but thay are not without some "opportunities to be successful".
They are a 2 ton truck depending on the front and rear axle combo. Mine has a 15000lb two speed rear driven by an SM420 4 speed tranny and the 292 six cylinder. The GVW on mine is 19200.
The biggest gotcha on this model with the 15000lb rear axle is the self adjusting rear brakes. Parts are very hard to find for this "experiment gone bad" that is unique to the '66 model year. Other than the brakes, you can find all the parts on the shelf at your local Napa store. The cab is the same as the 1/2 and 3/4 ton trucks except for the front doghouse.
This site is the best source of information. There are some real knowledgeable folks that visit hear.
Buy yourself a reprinted copy of the 1963 service manual and the 1966 supplement to it.
Holler when you need help. We will all jump in when we can.
BigMac
#143054 06/20/2005 5:30 PM
I owned several, '60-'66 L60-L80 LCF (Low Cab Forward)Chevy trucks. All of mine were V-8 equipted (327, 350, 348, 366, & 409).They are, indeed very good trucks. You can see them here, http://www.classiccoe.com/oldcoetrucks/6066.htm
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#143055 06/22/2005 9:17 AM
I have a '66 C-60,also with a 292/4 speed,single speed rear. Mine shows a 19,000 pound GVW too.I found out a power steering set up from a C-60 up to the mid 70's will work on a '66 but requires a bracket to be made,to mount the axle-end of the ram to the axle,and the linkage from the spindle to the steering box will need to be shortened an inch or so,to allow the steering box to center.
I had to replace my steering box,the bearings came out in about 90 pieces,many were half-ballbearings-no wonder the steering kept locking up.
Also,get an electronic ignition from a newer 292 and swap it in.you'll be amazed how much better it'll run,and it'll make the plugs last longer too. On the down side,don't plan on going anywhere fast in it. I don't know what redline is on a 292,but at 3,000 rpm,mine goes about 45 mph. BTW-there are 2 water pumps available for the 292;one will work with the dual belt pulleys,the other won't.Different shaft lengths.
I found out "MAD Electrical.com" has a LOT of info on making your electrics work right.
Have fun!
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#143056 06/22/2005 11:41 PM
After rebuilding my 292 I can tach to about 3800 without strain. I have had it to 4200 in a pinch but would not make a habit of it. My 54 6100 speedo is caput so I don't know how fast that might be but given all the evidence I would say about 60. Jim
#143057 07/17/2005 1:20 PM
Junior Member
Junior Member
Thanks for all the info yall.
Im enjoying this site!!
Jimmy
#143058 07/17/2005 8:12 PM
Hi Truckman,
My site www.chevyc60.com contains some info and is evolving whenever I can find some spare time.
Take a peek when you have some time...
PS: Post some pics of your '66 if you can...would love to take a look at it!!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#143059 07/18/2005 2:31 AM
Junior Member
Junior Member
Burgie Cool web page !!
I have some pics here >>http://client.webshots.com/album/380507692PtoyyL
Jimmy
#143060 07/18/2005 4:43 AM
Thanks Jimmy...
FYI: I sent you a personal mail...
Thanks...
Burgie
#143061 07/23/2005 9:09 PM
Junior Member
Junior Member
I can't believe I found someone with a truck just like mine!!! I have the same, a 66' c-60 flatbed with a 292 4speed. I am not sure about the rearend. I have several questions to ask if you don't mind. First, It overheats alot,and the only thing I changed was the distriutor,I went to HEI. I can't get the carb set with the timing. I am not sure where to set the timing cause I am not sure what year the motor is.Does it matter what year it is? I hope I didn't scare you with all of this. Thanks for your help. Jeff
For a year now I Too have owned a 1966 c_60. 2speed axle. As for the engine there was a 350 chevy I pulled out not sure what was in it before the truck is a wrecker/hauler it will carry a car above the cab one on the back truck bed is powered by two large hydro cylinders you can also insert the stinger and tow a car aswell truck has big winch driven by pto off the motor/trans. Any help would be great I have never found another one like it online! [email protected]
Welcome to the site David.
You sure found an old thread there ('05).
Nice looking truck. I'm curious to what the GVW is it. If you plan to haul 3 at a time you need to make sure that you are not overloaded, legally.
Let us know in detail how we can help you with it.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
fastdak check your timing maybe out of timing making it run hot speed6351 so you installed a ram and a pump? Not a P/S box?From a 70s? thanks Timbuk
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
I know it is an oldie, but some helpful info in this thread for the Bigger Bolt Owners.
Originally Posted by BigMac
Truckman,
BigMac
Is this something I should have to worry about on my 1964-1966 School Bus Chassis with a 327 v8? I too am planning on going through the brake system in a couple of weeks and I am trying to order parts by middle of this week so they'll be here. I know pretty much everything will need replacing, so switching to a different brake system is ok with me too if that is possible. I just need some help ordering the right parts. With the "truck" being 3 hours away that makes things difficult.
Spanky, what all do you know about these trucks (mine is a Bus chassis with a 327 v8)......specifically the tuneup parts, and the brake parts.
Originally Posted by Burgie
Hi Truckman,
Nice Site. PM SENT BURGIE.
