5 members (Guitplayer, tclederman, Leo, stlcardinalsguy, FAST55), 65 guests, and 2 robots.
Topics128,050
Posts1,055,673
#1430427 11/17/2021 3:07 AM
The 46 Chevy pickup front bumper has 5 holes. Two on the right and left side are for the brackets. What is the one in the center for?
If they're like the AD bumpers that have 5 holes, the center one holds the splash apron to the bumper.
I have several GMC's, 1941-1946. All the front bumpers have four holes. The inside of the bumpers have a bracket in the center that holds a support bracket for the hand start crank. I have never seen any splash aprons on a GMC or Chev of that vintage.
1946 with WWII 270
That center bolt is used to mount a bracket that helps align and support the hand crank while it’s used to start the engine, as maybe needed.
Center hole is for hand crank guide and the factory accessory grille guard. Also the front bumper on a GMC is much heftier than the Chevy bumper, but bolts right on, was lucky to find this one.
1946 1/2-Ton Chevy
Thanks all for the response. Do you know if and where these are available?
Place a Parts Wanted Ad in the Swap Meet Forum.
I have four GMC's and none have a hole like your Chev JiMerit Boltr#43. Some are thin some are thicker.
1946 with WWII 270
Believe it or not this bumper sprang back to shape after it was unbolted and I was able to reuse it. They don't make spring steel like that any more.
1946 with WWII 270
Too bad the fender didn't do that as well. frown
Yes, but I had a friend, fellow veteran that donated a nos fender. Grill was hard to find but I manage to find one of those untweeked.
1946 with WWII 270
