1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A few pics of a Stovebolt or any inline 4,6, or 8 cylinder engine lift bar I whipped together in a short time with scrap material, a cutting torch, and a couple of long 3/8-16 bolts. The lift point can be moved to holding the engine near vertical at the front to balanced level with the trans attached. Used for 20 years with zero issues and hanging from a single point can be tilted, rolled, or angled with little resistance. Really a work saver. Overall view shows long bolts that run through rocker stands, 7/16 nuts welded on underside of bolt holes to space bar above rockers, and a series of lift point holes to hold engine at desired angle. [img]https://i.postimg.cc/XG40Nsbz/engine-lift-bar-004.jpg[/img][img]https://i.postimg.cc/XG40Nsbz/engine-lift-bar-004.jpg[/img]Hole enlarged on top of bar to allow socket and extension [img]https://i.postimg.cc/nsskWDwS/engine-lift-bar-002.jpg[/img]
Evan
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | that looks handy.
thanks for sharing.
-Woog | | |
