Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (78buckshot, Hotrod Lincoln, klhansen, DoubleB, 55shaker), 113 guests, and 4 robots.
Topics128,288
Posts1,058,577
Members48,492
#142947 06/12/2005 5:57 PM
I have received a tach as a fathers day gift but it has no instructions with it. There are four wires black, green,white, and red. I am pretty sure that the black is ground, the red is for the backlite, and am not sure what the others are for... I want to connect with a stock 235, and if you take the cup off there are a couple of loops of wire inside. My memory tells me that 40 years ago one of these loops had to be snipped. No brand name on the tach, but is has a couple of mooneyes on the face.... Help!
How you get there is more important than when!
1959 apacheeeeee short orig
92 and 05 harley customs
#142948 06/12/2005 7:40 PM
U
U Offline
Try and go to this site. http://www.mooneyes.com/instructions.PDF
It has instructions for the Mooneye gauges. You need Adobe Acrobat to read it. I hope this helps.
Aloha,
Keoni
#142949 06/12/2005 8:25 PM
I really appreciate your help UR2 SLO but I guess that my college degree was from the wrong century cause it is all greek to me , as Ive got wires coming from the back of the unit and the setup decsribed at that site seem to all use a module or plate, maybe a sending unit of some sort.... I have trouble reading between the lines. soooooo!
#142950 06/12/2005 8:45 PM
Red= power or battery
Black= ground
White= lights (splice into your dash lights)
Green= negative side of coil
Should be good to go.
#142951 06/12/2005 11:29 PM
I appreciate it shipwright. that is the kind of info that I was looking for ,,, you know.. how to for dummies... I had a 49-5window back in the 60s. wish I still had it.. Thanks.
both hands on the wheel and a big grin on your face!
