| | | Forums66 Topics128,109 Posts1,056,261 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I'm about ready to tackle installation of my windshield and rear glass, 1953 half ton. I've read the shop manual, and have searched past threads. I would like to know what windshield sealant you guys have used, and recommend. Also, if you can provide any tips or advice that you think might help me, I'll really appreciate it.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 |
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Mike Burns Iv'e never been able to see where GM ever put sealant on cab glass,a used back glass from the junk yard comes out easily after you knife the rubber out of the way. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | It’s in the 48 thru 53 shop manual, in the body section. Specifically, it’s on page 1-4. It only calls for sealant for the windshield. It also soecifically says that no sealant was used on the back windows.
| | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | I had my glass installed with no sealant, all new rubber gaskets and they leaked ! Maybe its the new rubber!, a little sealant no more leaks and never hardens . I don't know my tuck is a 56 maybe you need nothing
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . , a little sealant no more leaks and never hardens . . . Ditto on my 1954 trucks. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | The instructions in the shop manual definately call for sealant on the windshield. I think that you guys just confirmed it.
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | The book says to run a 3/16 bead on the outside of the pinch weld flange, all the way around, prior to doing anything else. then, if I remember right, it calls for shooting a little bead under the rubber in the glass groove too, after the install.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
