4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 17 | I have received a tach as a fathers day gift but it has no instructions with it. There are four wires black, green,white, and red. I am pretty sure that the black is ground, the red is for the backlite, and am not sure what the others are for... I want to connect with a stock 235, and if you take the cup off there are a couple of loops of wire inside. My memory tells me that 40 years ago one of these loops had to be snipped. No brand name on the tach, but is has a couple of mooneyes on the face.... Help! | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Try and go to this site. http://www.mooneyes.com/instructions.PDF It has instructions for the Mooneye gauges. You need Adobe Acrobat to read it. I hope this helps. Aloha, Keoni | | | | | Joined: Jun 2005 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 17 | I really appreciate your help UR2 SLO but I guess that my college degree was from the wrong century cause it is all greek to me , as Ive got wires coming from the back of the unit and the setup decsribed at that site seem to all use a module or plate, maybe a sending unit of some sort.... I have trouble reading between the lines. soooooo! | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Red= power or battery Black= ground White= lights (splice into your dash lights) Green= negative side of coil
Should be good to go. | | | | | Joined: Jun 2005 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 17 | I appreciate it shipwright. that is the kind of info that I was looking for ,,, you know.. how to for dummies... I had a 49-5window back in the 60s. wish I still had it.. Thanks. both hands on the wheel and a big grin on your face! | | |
