7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51), 130 guests, and 2 robots.
Topics128,109
Posts1,056,267
Members48,439
I'm about ready to tackle installation of my windshield and rear glass, 1953 half ton. I've read the shop manual, and have searched past threads. I would like to know what windshield sealant you guys have used, and recommend. Also, if you can provide any tips or advice that you think might help me, I'll really appreciate it.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
!956 Gmc Napco 4x4 Factory line built .
Mike Burns Iv'e never been able to see where GM ever put sealant on cab glass,a used back glass from the junk yard comes out easily after you knife the rubber out of the way.
It’s in the 48 thru 53 shop manual, in the body section. Specifically, it’s on page 1-4. It only calls for sealant for the windshield. It also soecifically says that no sealant was used on the back windows.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
I had my glass installed with no sealant, all new rubber gaskets and they leaked ! Maybe its the new rubber!, a little sealant no more leaks and never hardens . I don't know my tuck is a 56 maybe you need nothing
Originally Posted by sack
. . . , a little sealant no more leaks and never hardens . . .
Ditto on my 1954 trucks.
The instructions in the shop manual definately call for sealant on the windshield. I think that you guys just confirmed it.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
The book says to run a 3/16 bead on the outside of the pinch weld flange, all the way around, prior to doing anything else. then, if I remember right, it calls for shooting a little bead under the rubber in the glass groove too, after the install.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
