| | | Forums66 Topics128,261 Posts1,058,341 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 104 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 104 | Anybody have experience rebuilding the 47-53 3/4 ton steering gearbox? I'm in mine now and could sure use some help finding parts. I could probably get away with making my own gaskets and checking with the local bearing supplier for bearings and races possibly even the bushings but, I'd sure like to just find a kit... | | | | | Joined: Feb 2000 Posts: 5,264 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,264 | | | | | | Joined: Dec 2020 Posts: 104 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 104 | Yeah, Classic parts said theirs is only for the 1/2 ton, thanks for that link though Joe H. Looks like I'm going to try out the one on E-bay and hope for the best. I'll let you all Know how it goes. | | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | The service manual says steering gears are the same from 1/2 ton thru 1-1/2 ton trucks, except for forward control trucks, school busses, etc. The difference in the bigger trucks is more balls in the recirculating nut.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 104 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 104 | That's great news! I ordered the one from E-bay. It should be here by Saturday I think. Time to get cracking on cleaning up the old parts. Thanks again for all the help. | | |
