For those of you who may have searched for modern paint codes and came up short - The PPG 32669 paint code for Thistle Gray (Radiator grill bars 1954 Chevy Truck 3604) crosses to an Akzo Nobel FLNA7076.
I tried and tried to find the 32983 Anvil Gray ( Bumper and Hub Caps 1954 Chevy Truck 3604) and lo and behold I called Orielly's Auto Parts and they are able to use the PPG 32983 and cross reference within their paint system.
I'm hoping this information is helpful to others. I have not sprayed either mixed paint color but once I do, I'll take pics and share them.
Have a great weekend , everyone!
Ron
Ron - - Dusty53 1954 Chevy 3604 In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel."
Dido Thanks. My original paint on the grill was still there, so I matched that up at the Sherwin Williams automotive paint dealer. The bumper paint was all gone. I will check out O'Reilly's for the Anvil gray.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
Ok , here's some pics. Not sure if these will provide enough clarity. Let me know if you need more pics .
I tried and tried to find the 32983 Anvil Gray ( Bumper and Hub Caps 1954 Chevy Truck 3604) and lo and behold I called Orielly's Auto Parts and they are able to use the PPG 32983 and cross reference within their paint system. Ron
I tried Orielly's. They told me there was no cross reference for the PPG #. Maybe the counter guy didn't know how to correctly search.
Do you have the O'Reilly's number or color name that you can share? That would help others looking for Anvil Gray.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Sorry I missed this request. Here's what I've got for both colors . If you need additional info please PM me and that way I'll see it in time to react. Thanks for the suggestion Kevin.
First two pics are of the paint can, Anvil Gray
Second two pics are of the Thistle Gray
Ron
