| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 2 Junior Member | | Junior Member Joined: Oct 2004 Posts: 2 | I recently purchased a 1946 2 ton flatbed. I really want to use this truck in my constuction business. There is nothing like an Art Deco Chevy to grab attention... BUT, 45 MPH on a California freeway is suicide! So... my question is, can I swap gears in the rearend of my truck?
I plan on swapping out the 235 for a small block chevy to handle the higher gearing. I would even go to a big block if necessary. Whatever it takes to get this baby up to 70!! Is a gear swap even possible? Is there another rear end I can swap in to make the gear change possible?
Thanks.
BTW... GREAT site, excellent Information, LOVE IT! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Some one on this board has put modern 1-ton IFS and rear axle and suspention under an Art Deco truck. I looked for the thread and link to pictures but couldn't find it. If he doesn't self-identify I'll post it later from home.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I have a 45 Chevy 2 ton, yup 45 mph is slow, but it gets attention Getting it up to 70 is no problem,but brakes and handling at twice the speed it was designed to go may be a problem. There is a 5.43 gear set, probably hard to find a good one.With the 6.17's, 60 mph is around 3400 rpm, no problem for a small block at that rpm.GM used low gears right up into the 70's on trucks of this size when V-8's were commonplace. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by OldSub: If he doesn't self-identify I'll post it later from home. Quoting myself! At least I won't be saying this guy was wrong! I didn't find the thread, but here are the pictures. 45 with C30 suspension
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I did a rear and front swap on a 46 chevy 1 1/2 ton. used a 74 chevy cutaway 1 ton front and rear axle. narrowed the front ifs 5 1/2 inches and the rear was a bit wider, but we sent it out and had a car hauler bed on it so the wider rear worked good for that.350/700r4 tranny and it will handle any freeway.rides very nice Phil | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Welcome Big46. I see your questions are being answered so I'll just say howdy and tell you to be sure to check out the other areas of the site, like the Tech Tips and Features. Swap Meet is also a good place to look for stuff.
Thanks for stopping by! John
~ One of many.
| | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Big46, I'll throw in with Tony (Truckedup) on this one. I am not intent upon raining on your parade, but make sure you have a safe, enjoyable parade.
California freeways are nuthin' to mess with--little bitty ricers goin' 80 mph flittin' around monster grocery carts (Hummers, Escalades, Excursions, and such preferred chariots for modern shoppers) doin' 75--in an old truck designed and outfitted (as Tony says) for 45 mph.
If you stick different gears in the rear end to increase angular momentum of the tire at the tire-road surface interface (that makes it go faster--sorta like a new paint job!), you necessarily change all the parameters viz. a viz. the acceleration (but more importantly, deceleration) equation, not to mention steering, mirrors, stop lights, ad nauseam.
I would highly recommend you do something before modifications that affect the coefficient of friction between the brake pads and the drums, to beef up the braking power delivery system (that Rube Goldberg bunch of pedal-levers-foot long cylinder-fluid tubes-wheel cylinders-expansive lever actuators-spring loaded pads). Else, it is but a matter of time until you will find yourself with a little fly in front of you that you could stomp on, or a unit transportation delivery vehicle larger than my Grandad's house, doing wierd things in front of you. Por supuesto you will stomp down on the brake pedal, maybe with both feet (who gives a #@%&@ about the clutch at a moment like this!), which will take up an inordinate amount of your 1 to 2 second reaction time before you factor in the reaction time of Rube's contraptions, and that miniscule delay at 70 per can easily account for 100 or more feet of roadway you just kissed "goodby" even before your precious truck begins turning angular tire momentum into dissipated heat energy. Stand on the brakes too much, and you will literally "burn rubber" (or whatever synthetic concoction your tires purport to be) to transform the kinetic energy of a loaded single unit truck into expended waste.
Single unit trucks, loaded, are to be respected--both as objects of great admiration and for what they can do for us as well as to us.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
| | | | | Joined: Oct 2004 Posts: 2 Junior Member | | Junior Member Joined: Oct 2004 Posts: 2 | Thanks for the input, advice and welcome. All are well received and appreciated.
No doubt... other factors need to be addressed, not just "GO FAST". Don't worry, I won't be throwin' in a big block and some higher gears and go tearing down the freeway!!
I'm just trying to get the truck "driveable". Don't get me wrong... the ol' girl is great fun just like it is, but not for use on a daily basis.
Any suggestions for modern 1-ton or even 2-ton drivetrain? This would address both the go fast and safety issues and retain the classic good looks of an art deco chevy.
Thanks again. | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | If you could find a newer Chevy/GMC big truck, that would make a better donor than a one ton. there should be plenty of them around in Kalifornia, then if you swap the axles and brake rigging, that may get you a bit more speed and better stopping as well. you mite even consider just swapping the older 46 on to the newer chassis, but to keep the stock looks. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | if you have 10 hole rear wheels you can use the late model rear from an r.v. or 3500 series gm truck. wheel size on that rear end is 19.5 which is only a tad bigger than a 16 inch wheel, however the 20 inch stock wheels you have will bolt to them. there is a slight difference in wheels, but i have seen the late model diff with old wheels and it seems to work. you can also just install the late model diff and change the entire set of wheels to 19.5. on the late model diff is much wider brakes and better friction material for increased stopping ability, but remember the front brakes are very important to, so there's the weakest link. 70 mph with the bolt ought to be pretty easy to attain, with an improvement in stopping ability. maybe milage of about 10 or so. if you change the diff, i would sure switch to a dual master cylinder, as there is definitly a weak link in the ability to stop.
ought to be a pretty easy swap, and sure makes sense to me. | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | if youre realy gonna use it in your busness it would be good to upgrade to bigger parts most one tons are only rated at 10,000 lbs so if your truck ways 7000 lbs with everything that only leaves 3000lbs for load wich is allright but if your gonna hual dirt, gravel, and lumber you might need more. if you put metalic shoes on the front and had power brakes all the way around it should stop pretty good | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i think he's got a 2 tonner. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | somebody who lurks around here put a 454 big block in their '46 2 ton... they were still working on it... I can't recall their nick atm...
I think those '41-'46 2 tons are way cool.
-W | | |
