3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 64 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#1427131 10/18/2021 2:55 AM
I just installed an electric fuel pump on my 52 Chevy truck with a 235 engine mustang fuel tank.
Plans are to use the pump to prime carburetor and a back up fuel pump.
I want to put a fuse in the best location close to the electric pump or closer to the toggle switch?
I fuse I have is covered in a rubber boot with a cap on it so fuse would probably stay dry .
This is no longer fun
latroca52 #1427136 10/18/2021 3:34 AM
Crusing in the Passing Lane
How many PSI is the new pump? It needs to be in the 3 to 5 range for continuous running.
Ed
latroca52 #1427138 10/18/2021 4:07 AM
Electrically, it doesn't matter where the fuse is. Put it on the hot wire where it's most convenient to service.
latroca52 #1427139 10/18/2021 6:26 AM
I prefer to put fuses closer to the power source (battery) because if you get a short upstream from the fuse, it won't do any good.
The majority of the time fuses get blown because the terminals on whatever you are fusing get shorted, or a failure in the pump. For those cases you can put the fuse anywhere you like, even on the ground side.
I had a truck catch fire under the dash because a wire rubbed through the insulation between the battery and the fuse and shortes out under the dash. Fortunately no one was hurt (though Franklin still won't ride in any of my vehicles 15 years later).
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
latroca52 #1427546 10/22/2021 2:05 AM
Thanks for all reply’s I will be putting the fuse between the ignition switch and the toggle switch
