| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | I just installed an electric fuel pump on my 52 Chevy truck with a 235 engine mustang fuel tank. Plans are to use the pump to prime carburetor and a back up fuel pump. I want to put a fuse in the best location close to the electric pump or closer to the toggle switch? I fuse I have is covered in a rubber boot with a cap on it so fuse would probably stay dry . Thanks
This is no longer fun
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | How many PSI is the new pump? It needs to be in the 3 to 5 range for continuous running.
Ed
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Electrically, it doesn't matter where the fuse is. Put it on the hot wire where it's most convenient to service.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I prefer to put fuses closer to the power source (battery) because if you get a short upstream from the fuse, it won't do any good.
The majority of the time fuses get blown because the terminals on whatever you are fusing get shorted, or a failure in the pump. For those cases you can put the fuse anywhere you like, even on the ground side.
I had a truck catch fire under the dash because a wire rubbed through the insulation between the battery and the fuse and shortes out under the dash. Fortunately no one was hurt (though Franklin still won't ride in any of my vehicles 15 years later). | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks for all reply’s I will be putting the fuse between the ignition switch and the toggle switch
