2 members (DIY.MechanicMike, Stovebolt48), 76 guests, and 3 robots.
Topics128,179
Posts1,057,064
Members48,460
#1426605 10/12/2021 12:06 PM
Does anyone have a picture and or description of the hydraulic clutch line from the master cylinder to the slave cylinder for a 62 c10 235 L6?
the ones I removed has 2 metal lines with a high pressure braided flex line connecting the two. is this a factory setup? If so where can I get the replacement flex, (rubber) hose?
Thnak You.
Have e Great Day
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
Crusing in the Passing Lane
Should be able to get new line and hose at FLAP.
Ed
It is correct as a 1 piece hard line that runs down firewall and curves along the bell housing, clipped to bell housing at the 10 oclock position (as facing the firewall) and then to slave cylinder. I believe same routing and attachment to BH with L6. I dont have a picture of entire routing but a few to give you the idea. Likely mine came from Inline tube.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks Ed,
1964 C10
Thanks Hambone,
1964 C10
was the hydraulic slave clutch original in a 1/2 ton '62? ...anyone? I dont remember my '63 1/2 ton with a later 327 in it having a hydraulic clutch while I think our '66 2 ton grain truck did.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
