7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy), 67 guests, and 3 robots.
Topics128,130
Posts1,056,713
Members48,454
1 Offline
As the title says, looking for source(s) for 5.43 gearset 2352908?? These are supposed to fit the GM H110 axle. Thanks for any tips!
WW2Chevy
1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
Google the part number and contact the vendors that claim to have a gearset.
1 Offline
I've already done that (and continue to do so). This post was part of that effort to turn over as many stones as possible. Most places either show them back-ordered, out of stock, or just don't indicate. I've called a bunch of places, and most take my name and number and tell me they'll check and get back. Everyone so far has said they've checked their sources and come up empty.
I've gone back to my notes from 15-18 years ago, and called a couple places that don't even have a web presence. No dice with them either. Really sad how many if the old places are just gone...
Thanks for your reply!
WW2Chevy
(Retro-roco)
Have you tried a search on GM H110 axle. GM built that axle for about 25 years. I think 1968 was about the last year. Are you trying to re ratio? Owners of 1 1/2 ton GM trucks have been trying to make them go faster for over 50 years and the 5.43 are probably getting scarce.
1 Offline
WW2Chevy
(Retro-roco)
1 Offline
Further research suggests that these gear sets were used in the H110 axles through the early 1980's. GM built a chassis designated P3 or P30, which was used for HD delivery van bodies (think large bread trucks), and also for RV chassis. The axles were often times referred to as banjo axles (see last picture).
WW2Chevy
(Retro-roco)
1 Offline
Thanks Mike,
I'm pretty sure I've read every page on this forum related to the 5.43 gear set. Great information available, EXCEPT where a guy can find a set... ARGGHH!!
WW2Chevy
(Retro-roco)
The elusive 5.43! Did you try the place that mechanic58 got his from in my linked thread?
1 Offline
Yep, I tried them. That was 6 years ago, and when I called, was told they sell wholesale only.
WW2Chevy
(Retro-roco)
For many years I bought gears, etc from Crane Carrier/Truck Parts Specialists. They got out of the business about 10 years ago. I understand the manager, Jim Youngs became manager at Inter-Continental Gear & Brake . I think it would be worth giving them a call again.
1 Offline
Any one have a tip on a used set?? These were in use for 40+ years and now they can't be found??
WW2Chevy
(Retro-roco)
Do both ends of your truck use the same gears?
Mike
1936 1-1/2 Ton (RD) Stake Body Original
1 Offline
Yep, both use the exact same differential.
WW2Chevy
(Retro-roco)
I have one ring and pinion of the elusive 5.43 set. I’m no genius nor have I been hoarding truck parts for decades. I’m just one occasionally lucky SOB who watched and waited and searched on eBay. Due to recently acquiring a new rear axle for my 1940 big bolt, I’ll need to sell my 5.43 H110 gears. I’ll get some pics and tooth count posted up.
Tooth count is 38/7. That works out to a 5.428571428571429 ratio.
Pics below. I don’t have any other part numbers.
Tony selling outside the Swap Meet Forum is prohibited. Please conduct your business dealings there or by Private Messages. Thank you, the Stovebolt Staff.
No problem not selling yet but when I do I’ll post up in swap meet.
Moderated
Moderated
Still available?
Moderated
Moderated
Tony, do you still have the 5.43 gear set?
