| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6 Junior Member | | Junior Member Joined: Mar 2004 Posts: 6 | I'm building a 49 gmc with a 22000 pound weight rating, (Ser. no. FC 303)I've been under the assumption that due to the high weight, it would cost an arm and a leg to register every year. Can any one prove or disprove this assumption? I live in california, but am moving to michigan as soon as I finish this beast. I'm 24 years old and on my way to a slightly late engineering education, so if the cost will be too high, I might consider, shall we say, alternatives..........thank you for any replies. to add a detail, I need to have no restriction on the registration, so if there is some cheap antique vehicle reg price, with a milage limit or something, I would be interested to hear about it, but it wouldn't really do me any good as I will be driving it every day when I'm done. thanks again 49 gmc | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here in Iowa, you chose how many tons you want to register your truck for. I only put 6 ton license on mine since that's about all the old six can handle and I'm not usually more than 2 miles from home. You may want to go to the license plate office and ask about Californias' policies, Scott | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | In NY you can declare a gross weight less than what's listed on the vehicle ID plate.The gross on my 45 2 ton Chevy is 13,500,registered it for 6000 gross.This flat bed truck weighs 4450 lbs on the scale.I haul stuff,but not usually anything over 1500 lbs.I believe,maybe, anything over 10,000 gross is subject to state DOT regulations. | | | | | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | When I purchased my Dodge in California, it had Historical plates. It too has a 22k GVW. Now here in Washington I have Collector plates and once you regester it that wat you never have to pay again. I have Collector plates on my Cadillac, my GMC and the Dodge.
You have options usually...
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
| | | | | Joined: Mar 2004 Posts: 6 Junior Member | | Junior Member Joined: Mar 2004 Posts: 6 | An update- it seems that if I get the truck weighed, then I can declare my wieght to be under 10000 pounds and avoid the weight fees. thanks to all who responded. this makes my life much easier. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Just don't get caught weighing more than your registered weight.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey 49gmc. where at on your truck did you find that gvw. of 22000lb. A FC303, is a 300 series 1 1/2 ton GMC, rated at 15000lb. gvw. 350 series 2 ton GMC's have a gvw. of 16000lb., 400 series 2 1/2 ton 18000lb. gvw., 450 series 3 ton 19500lb. gvw., & 470 series 3 1/2 ton GMC 22000lb. gvw. Just curious. http://community.webshots.com/user/snubnose4754 | | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | My fire truck has an antique tag..it never expires and has no weight restriction it cost 25 bucks | | | | | Joined: Mar 2004 Posts: 6 Junior Member | | Junior Member Joined: Mar 2004 Posts: 6 | Spanky, maybe we got crossed up between cargo weight and truck + cargo weight. I got my info from the serial number plate and it goes like this:"serial fc 303 xxxx certified net horsepower- 89.5 at 3000 rpm maximum gross weight- 13000 maximum gross combination weight- 22000"
Don gwarty,
Does that tag carry use restrictions, such as to or from historical vehicle events or any thing like that?
take it easy
49 gmc | | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | the tag does not carry restrictions...the insurance i have does. it says not to be driven daily. but has no mileage restrictions. | | |
