8 members (John Dlugos, rfs56trk, BCBill, Otto Skorzeny, Dusty53, Buckeye998, Chip O, WICruiser), 183 guests, and 1 robot.
Topics128,101
Posts1,056,172
Members48,436
I
Junior Member
Junior Member
I Offline
I'm new here and am hoping to find some parts and info. I have a 1947 GMC COE, with a 318 inline six, a five speed tranny and a two speed rear end. it also has air brakes. It has sat for quite a few years and kids broke all the glass and gauges. So those are on my wish list. the thing I need ASAP is the gear reduction starter. it hung up while it was running. It's a Delco Remy 1108451 6M19. If anyone can guide me in locating one, it would be great. Thanks for the help.
Jake
You would be a lot better if you could find someone to rebuild your starter. I know from experience. There is a rebuilder in Phoenix who does this kind of work so I imagine there has to be someone closer to you who can do it. Jim
Welcome to the Stovebolt! I'm on Bainbridge, so not far away.
Is this truck a Cannon Ball model?
The first GMC "Cannonball" COE's came out in 1950.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
I
Junior Member
Junior Member
I Offline
Thanks for the welcome. I found a rebuilder in Tacoma and the starter is in his hands. Now it's just finding the rest of the stuff. I've been told this is a commercial model and thats why I couldn't get the right starter. I now have two spares for my 53 2 ton Chevy cat truck. Glad to find a spot to talk old iron.
Most of the glass on that model will be flat, and can be cut by any good automotive glass shop. I'm not sure about the windshield. Just be sure they use the sandwich-type safety glass, not regular plate glass. I doubt if a reputable glass shop would do that anyway! If there's not enough of the old windows left to use as a pattern, carefully cut out a cardboard template for the glass shop to use as a pattern, but be sure to allow for the thickness of the gasket.
Big Bolt Shop Curmudgeon
Well, Ironjake, as you see you've come to the right place for information and suggestions on "how to..."
If you've gone pokin' around the Garage, you probably already know aoubt the other interesting things going on here 24 hours a day. You'll meet people from everywhere around the world.
Thanks,fellers, for gettin' right to Ironjake's questions.
And if you can crawl out form under the old COE long enough to take some pictures, there are a few 'Bolters who drool and get twitches every time they see a COE.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
I
Junior Member
Junior Member
I Offline
I'm working on a few pics of the old beast. I got the starter rebuilt and am on to the tune up. It has a 318 inline and the exhaust manifold is falling apart. Any idea who might have one?
I forgot to mention that I also have a 53 2 ton Chevy that I use to haul my dozer and I have a 50 Chev 1/2 ton that I got at age 14. at 46 and older than dirt, that ain't too bad. Thanks for the help.
Your saying 318 inline just to be sure is that a gas motor? I don't think they were putting the diesels in that early If it were diesel the parts are still available. 6-71's were produced from the 40's thru 80's at least. With 53 series coming in a little later. The reason I was asking was the 6-71 most common was the 238 whereas the 8V-71 base was the 318. They were set to run about 2100rpm but a lot of folks set the govenor 2600 or better, run fine plenty of oil leaks. Spanky proably has better dates on the engines and when they went into COE trucks.
