1 members (RBs36), 172 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#1423310 09/08/2021 2:55 PM
I hate to admit it but i guess I just never messed with many snap rings......but always managed to get what I wanted.
Nevertheless, my question is ..... how do you measure for snap rings. Do you ask for he OD of the shaft or do you ask for the OD of the groove the snap ring goes in???
I suspect Grigg will jump on this question?!
Internal or external snap rings? I've always had good luck using the OD of the shaft and relying on the snap ring to fill the groove. We used to use Tru-Arc internal snap rings for piston pin locks, bit after losing a couple at high speed, we switched to Spiro-Lock rings that don't respond to high piston speeds and come adrift.
Moderator
Moderator
2 Offline
Spriro-lock rings work great, but can be a pain to remove.
Remember to bring that question up this weekend and we can look the specs up in my machinist bible.
But, I think you go by the diameter of the bottom of the groove on OD rings and the ID of the groove on ID rings.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
AD Addict & Tinkerer
Here are two links that show the dimensions of standard internal and external snap rings.
Internal https://www.arconring.com/stamped-retaining-rings/internal/
External https://www.arconring.com/stamped-retaining-rings/external/
Phil
Project Journals
Stovebolt Gallery Forum
As usual, when you dig into things you find there is a whole lot more than just "meets the eye". Thanks fellows.
I will say, before I went looking for them I used a set of dials and checked the OD of both the outside of shaft and then OD of the ring groove. As we sometimes say, heck, that's more than I needed to know!
Thanks again.
Moderated by  MNSmith
