| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I hate to admit it but i guess I just never messed with many snap rings......but always managed to get what I wanted. Nevertheless, my question is ..... how do you measure for snap rings. Do you ask for he OD of the shaft or do you ask for the OD of the groove the snap ring goes in??? I suspect Grigg will jump on this question?! | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Internal or external snap rings? I've always had good luck using the OD of the shaft and relying on the snap ring to fill the groove. We used to use Tru-Arc internal snap rings for piston pin locks, bit after losing a couple at high speed, we switched to Spiro-Lock rings that don't respond to high piston speeds and come adrift. Jerry
| | | | | Joined: Aug 2001 Posts: 3,598 Moderator | | Moderator Joined: Aug 2001 Posts: 3,598 | Spriro-lock rings work great, but can be a pain to remove. Remember to bring that question up this weekend and we can look the specs up in my machinist bible. But, I think you go by the diameter of the bottom of the groove on OD rings and the ID of the groove on ID rings.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 |
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | As usual, when you dig into things you find there is a whole lot more than just "meets the eye". Thanks fellows. I will say, before I went looking for them I used a set of dials and checked the OD of both the outside of shaft and then OD of the ring groove. As we sometimes say, heck, that's more than I needed to know!
Thanks again. | | |
