| | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 25 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 25 | I got some great HELP on here and wanted to say THANK YOU to those that chimed in. The clutch disc WAS rusted to the flywheel and when I put a putty knife in and broke them apart all is good now! So again I say this forum is AWESOME and I really appreciate all the help! | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If thre truck is going to be parked for some time between drives, the trick about using a piece of broom stick to hold the clutch pedal down is a good one to remember. Cut a piece of broomstick, 2X4 or even a piece of PVC pipe just long enough to wedge between the front of the seat, or maybe the steering wheel, and the clutch pedal when it's depressed. If the clutch pedal is happy, hold it down anyway!  Jerry
| | | | | Joined: Sep 2010 Posts: 1,706 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,706 | I've had that happen a few times with my '38. I don't always remember to use Jerry's suggestion. I think it's caused by our humidity in Florida. I'm traveling now and hope it's not stuck when I get back in 2 weeks. I forgot again! Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | My '47 likes to do that also. I keep a piece of 1x4 in the cab for that purpose. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That has happened a few times with my 38. I've been lucky enough to be able to free mine by driving it while holding the clutch pedal in until it finally breaks loose. I now carry a piece of 1x2 that I use to hold the pedal down by wedging it between the pedal and bottom lip of the dash.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Don’t know if propping clutch pedal down long term would would weaken clutch springs after a while?
Ed
