| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 4 Junior Member | | Junior Member Joined: Feb 2004 Posts: 4 | Does anybody know if anyone makes a non- split rim wheel for a 46 2 ton? Two of my 6 wheels need replacing anyway and I dread messing with the splits.
Eric
46 Chevy 2 ton 51 Ward LaFrance Fire Engine 54 Ford NAA 56 Case 400
| | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | I too would be very interested. I know after doing a search that there is a rim that fits the 10 lug but the center hole is too big. The only other choice is to have Alcoa build you one which will be big $$$$$$$$$$!!  | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | try wheels off mid 90's chevy 3500hd with a solid front axle. they have the right bolt spacing but are 19.5" instead of 20" so you will need tires also.
rh | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | http://www.stocktonwheel.com <- they'll make anything. I'm not sayin' you'll want to pay them to do it... but they'll make it. -W | | |
