4 members (Steelonsteel, Woodcmiami, Gray_Ghost, Hotrod Lincoln), 70 guests, and 2 robots.
Topics128,050
Posts1,055,760
#142141 04/05/2005 4:48 PM
EDK
Offline
Junior Member
Junior Member
Does anybody know if anyone makes a non- split rim wheel for a 46 2 ton? Two of my 6 wheels need replacing anyway and I dread messing with the splits.
Eric
46 Chevy 2 ton
51 Ward LaFrance Fire Engine
54 Ford NAA
56 Case 400
#142142 04/05/2005 8:14 PM
U
U Offline
I too would be very interested. I know after doing a search that there is a rim that fits the 10 lug but the center hole is too big. The only other choice is to have Alcoa build you one which will be big $$$$$$$$$$!! eek
#142143 04/06/2005 2:01 PM
I
I Offline
try wheels off mid 90's chevy 3500hd with a solid front axle. they have the right bolt spacing but are 19.5" instead of 20" so you will need tires also.
rh
#142144 04/15/2005 12:02 PM
Socket Breaker
Socket Breaker
http://www.stocktonwheel.com <- they'll make anything. I'm not sayin' you'll want to pay them to do it... but they'll make it.
-W
