| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | What emblem is supposed to be attached to the grille on a 1937 1 1/2 ton truck? In the center, left to right, and about 3/4 of the way up from the bottom of the grille there is a bolt with a shallow rectangular head that shows to font of the grille. Looks to me like an emblem should go there. Can someone tell what that might be? | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The emblem says Chevrolet in the center,has wings that extend out a few inches.I found a 37 car emblem,it's not exactly shaped correctly,but very few know the difference. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Truckup's description is a good one. The emblem goes in the center vertical bar and there should be a hole to bolt it on. Sounds like the emblem has been broken away from the bolt that holds it. This emblem is available from a couple sources and I believe the price is $45 unless they went up witht the price of gas!! When ordering one ask if its painted. Sometimes they advertise them and then you find out its not painted! As information the side emblems are that way. The first set I bought wasn't painted like the originals. The painted ones today cost about 35 bucks each. I just ordered two new ones that are painted and they do look nice. | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Thanks guys for the help, I have ordered the emblem. The price was $58, however they did say it is painted. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | According to all sources I have checked, this is one part that is the same on the car and the truck for 1937. What you ordered should look great and be 100% correct.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Unfortunately the emblem I ordered arrived unpainted. The person who took my order said it was painted, the catalog I received with the order said unpainted. But the worst of it is the emblem does not fit the face of the grille. When placed on the grille, the tips of the wings on both sides touch the grille while the center (with the attaching bolt) is 1/4 inch from touching the grille. My grille is in very good original condition and is not bent. The emblem is undoubtedly cast and will not bend to conform to the face of the grille.
So I am back to searching for an acceptable grille emblem. Any help? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Post a picture of the one you recieved and I will keep my eyes out for one. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | That's the same story with the grille emblem I have,wasn't shaped to fit properly.I was told it was a car emblem,the truck and car grilles are similar only.I massaged it to fit,got to go easy on that crappy casting metal. It was unpainted,a small artist's brust and some paint took care of that. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | rplemmons email me, I found two, but I am not sure if they are truck or car. ........g | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If it's pot metal, you can toss it in the oven and reshape it once it's hot. 200-300 degrees works best for me. | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | First of all, thanks to all of you that helped toward a solution for my grille emblem. Praise and many thanks to "GMCpanel", it was your suggestion that brought things together. I Copied the profile of the grille in the area where the emblem mounts, transfered that profile to a piece of hardwood and shaped a buck to work (shape) the emblem against. I checked the temperature produced by my electric heat gun (approx 260 degrees F.)and used that as my heat source. With the emblem placed on the buck (a hole drilled to receive the mounting stud) I heated it and then applied pressure with the drill press. In just a few minutes the emblem moved against the buck. Hope this isn't confusing.
Anyhow I am ready to paint and install the emblem and am now asking for advice on the proper paint scheme. Thanks, Ralph | | |
