0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Aloha all,
My name is Keoni and I live in Hawaii. I just bought my 1948 Loadmaster and found your Forum, GREAT SITE!!. I have read some of the information on engines swaps and I would like to replace my 216 with a 350 just for extra power and reliability. I was wondering if anyone has put in and engine near this size and if so what adaptors I would need along with the pros and cons. I know that the brakes and such are not made do do over 50+ mph, but I really don't need to go that fast. I just want to haul dirt and stuff and be able to take the dog to the beach. Any info will be much appreciated. Again Aloha and this is an increadable web site.
Keoni | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | My new Baby! 48 Loadmaster | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hey Keoni, I've done said swap to one of my 48's and it involves modifying almost every system of the truck. You'll need to change the steering and brake systems just to clear the left exhaust system of a V-8. Also, you'll need to upgrade your electrical to 12 volts and find a bellhousing,clutch parts, a new engine mount design, a good radiator, and alot of fabrication skills to make it happen. I do, however, like my Loadmaster with P/S, P/B and V-8 power to work with over my stock one. If and when you want some more details, e-mail me, it's been a while since I did the conversion so I may need to go out to the truck to see what I did to it. Good luck which ever way you go, Scott | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Oh, BTW, welcome to the 'Bolt and nice choice of truck! Scott | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Thanks for the info guys!! I would like to do the easiest engine upgrade which I guess is the 235 way, so it sounds. Is there much to do besides the engine swap or is it just a replacement of the orriginal. I already have the 12 volt conversion done so I guess i'm one step closer. The brakes are all reworked, I have a new water pump,and carb. The only other work I have to do on it is fix some oil leaks and redo the interior. I checked with Chevyduty.com and they said the interior cab parts wont work since it is a 1.5 ton, is this true? I thought all the cab parts were the same as the 1/2 and 3/4 ton, only the exterior parts were different. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What cab parts are you talking about? I would think that there may be some diffrences in the are of the transmission cover. | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Keoni,
Wanted to say aloha yesterday but was busy with gallery submissions.
Since you are new to the Bolt, you may not know that it had it's humble (VERY humble) beginnings in Kaneohe Bay, HI. We were stationed there for three years and that's when John started this. He was suppose to be learning html in order to do a web site for the Marine Base there. So, since he had left his dear, sweet '39 back in Indian-noplace, IN ... this at least kept him in-touch with the hobby.
Welcome to the Bolt!
Aloha, Peg
~ One of many.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Welcome Keoni, A 261ci. Chevrolet 6 cyl., would be the way to go. A good second choice, is a 302ci. 6 cyl. GMC engine. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I see things different from most folks a lot of the time so here is my two cents worth.If your motor starts and runs good and speed is not a factor why not just fix the oil leaks and drive it. Some times you can get a lot of miles out of those old motors. You can allways do swap later.
I like old trucks
