0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
My Grandfather and Dad, as farmers did in the old days, built much of their own farm equipment and by the early '60s, when I was 10, they built a forklift to fill grain drills out in the plowed ground. The loose dirt required it to be 4-wheel drive so they started with a 1944 Chevrolet surplus Army truck. That truck was a great choice since it had a transfer case with a high and low range gear shift to go along with the standard 4-speed manual transmission.
They shortened up the frame as much as possible, obtained a used forklift mast, and somehow turned the differentials around so the normal forward gears actually drove it backwards. They added the hydraulics to run the mast and to steer it.
I distinctly remember my Dad proudly coming home with the 4” thick cast iron fenders he used for counterbalance weight over the single front tires which are now the back tires. This was much more attractive than the normal homemade forklifts of the time that used a block of concrete hung on the back.
Throughout my teenage years, I drove this forklift quite often around the farm. Jump ahead 25 years to the late '80s when dry land grain farming in California became un-profitable. The forklift was only used occasionally for odd jobs until the battery wouldn’t start it anymore. Then it remained parked in the weeds for another 25 years. When we started planting vineyards, and we needed a forklift to unload the many truckloads of steel stakes and trellis wire.
So, in 2013 I did enough work on it to get it going with the original 1944 Stovebolt that was only running on 4 or 5 cylinders, leaking oil that would foul the spark plugs. Talking to a mechanic, he informed me the 1944 Stovebolt wasn’t re-buildable since it had Babbitt bearings. But I did have another Stovebolt in a portable welder that my Grandfather and Dad built. Much to my amazement: it is a 1957.
I’m partially rebuilding this engine to go into the forklift which has now become a labor of nostalgic love.
This website and forum are awesome. I’m already getting some of my questions answered.
Thanks everyone,
Paul
1944 Chevy Army Truck and 1957 Chevy
"From out on the Farm"
Fox Offline
THAT is cool. I love the old farmer ingenuity.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Welcome to the 'bolt.. that is some real "Engine-uity" there
Another quality post.
Real Trucks Rattle
Welcome!
They did a nice job on that fork lift. It looks factory made! Glad to see you're getting it going again.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
As the picture shows, taken in 1959, my Dad is quite the Chevy man. He is drilling an Ag well, I'm the boy looking on, with the welder, I'm taking the 1957 Stovebolt out of, along side our 2-ton truck with the BelAir my Mom drove down to take the picture in the background. I'm not exactly sure what year the car or the truck was, just early '50s, those were sold long ago and only the welder remained. We still use the Ag well to irrigate vineyards.
Paul
Old Chevys
24601
24601
That may be the most unique vehicle on the web site! Wow, it *does* look factory made. And cool history!
Welcome aboard!
Take more pictures!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Simply put....I like it.
Moderator
Moderator
2 Online: Content
'54 Plymouth in the background? If you have more pictures, post them up!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
He said a Belair. Looks like a '54.
That would be my guess also.
Rich
1947 Loadmaster
yep, 54 Chevy for sure, enlarge it and look at the park lights!
Sorry I don't have any other pictures of the car. I just assumed it was a Chevy since that is all my Father and Grandfather ever purchased in the latter years.
AD Addict & Tinkerer
I agree 54 Chevy Belair
Phil
Project Journals
Stovebolt Gallery Forum
That original engine is probably a spray-oiler 235, which came out in 1941, an upsize of the 216 engine for medium-duty and larger trucks. Don't trash it- - - -your mechanic buddy might not be able to rebuild a Babbit-rod engine, but the mechanics I grew up around at my father' shop in the 1950's made their living doing it. Plenty of parts are still available, and there are still a few of us old geezers who know how to work with Babbit metal. It's also possible to bore out the rods and replace the Babbit with insert type bearings. The main bearings are already replaceable, and aluminum 235 pistons are a drop-in fit for the original cast iron ones. Currently, I'm modifying a Babbit-rod 216 by installing a pressurized crankshaft and aluminum pistons from a 235. It will be a 235 with full pressure oiling and a high volume oil pump that looks like a 216 from the outside. With different connecting rods and some creative stroke changing, a "216" can become a 258 cubic inch engine.
There's nothing wrong with the engine upgrade you're planning, but it would definitely be possible to rebuild the original engine if you choose to do it. Good luck!
Moderated by  J Lucas
