8 members (Jims46, 2-Ton, Otto Skorzeny, tclederman, Bill Hanlon, Millenimech, dt235sd, greenie-reddy), 131 guests, and 3 robots.
Topics128,191
Posts1,057,365
Members48,469
59 Apache 3100
59 Apache 3100
Prepping my 59 cab to paint next week. I have 4 holes (two on each side) & I'm not sure what they are for.
This truck was a maintenance truck for the state of California. My best guess is an attachment for a window shade
Anybody seen this before? THANKS
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
Rifle rack?
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Shoulder restraint for seat belt? Holes look small, though.
my 62' also has the same holes plus a few that go around the rear window. I also am mystified by them. sun visor is a great guess, maybe a gun rack but i would think you may need more holes than that.
62' GMC Fleetside 3/4 ton 235 4-speed.
Time makes fools of us all.
59 Apache 3100
59 Apache 3100
Thanks for the guesses everyone.
I thought gun rack myself but the holes are so small I don't think It would hold very much. The holes are not threaded if that helps.
so I think it's the aftermarket ( installed by owner) & not Factory
Maybe fire extinguishers since it be was a California state truck.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Crusty Old Sarge
Crusty Old Sarge
Grab Bar???
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
59 Apache 3100
59 Apache 3100
Fire extinguisher is a great guess. Flahlight holder maybe?
The last tune up sticker in the door is from 1983 , decommissioned in 1996. Was at the insane Asylum in Stockton,Ca.
Maybe just hooks for state safety vests and/or helmets.
1957 Chevy 3200
Daily Driver
Follow in the DITY
I was going to guess fire extinguisher also.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
If we are guessing then my input is a fan. bigger, center hole was for the wiring. I dont know of anything dealer installed in that area.
~ HB
1962 Chevrolet C10
1962 Suburban
AD Addict & Tinkerer
If you installed three point seat belts, you’ll recognize the bigger center hole. The pop rivet gives it away! There is a threaded backing plate that is being held in place with that pop rivet until the seat belt in bolted in place.
I have no idea what the other two holes are for. Probably made before the seatbelts were installed.
EDIT: I like DES57’s guess, fire extinguisher mount, prior to the seatbelts!
Phil
Project Journals
Stovebolt Gallery Forum
59 Apache 3100
59 Apache 3100
Thought I'd add an ending to my original post. I just got done painting the interior back to the original color for a 59 "Comanche Gold" . Purchased the paint from Jim Carters. A quart was enough to paint the entire interior, doors & all, but I almost ran out. Thanks again for everyone's input. I get so much help on stovebolt forums, I love it!
