4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
#141434 11/29/2004 1:09 AM
Junior Member
Junior Member
I have a 1950 Chevy 216 4 on the floor with a 5.13 rear end gearing. I top out at about 45 mph. Does any one else have this type of setup? I can bearely keep up with traffic on back roads! Engine runs strong and has not had any problems. Thanks
#141435 11/29/2004 1:44 AM
Welcome to the stovebolt and welcome to the biggest problem of a stock bolters life. That's about all you'll get out of a 216 and that should only be for a limited time. 216's don't have alot of horse power or oil pressure so they need alot of TLC to make them last. You'll get alot of advise here so keep checking in often. (take mine with a grain of salt usually)
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#141436 11/29/2004 2:21 AM
I had the same problem with my 51 1 ton pickup. topped out at 45 and sounded like all @#X% was gonna break loose. i put in a 235 i got for a hundred bucks, and a pumpkin out of a 72 3/4 ton, and i can handle any driving situation now.4:10 gears were perfect for me.
Phil
#141437 11/29/2004 3:38 AM
Some vendors offer packages to change your rear end gears without putting a newer model rear underneath. I've seen ads for overdrive units that bolt to the back of the trnsmission. there are also period auxilary transmissions. Brown Lipe etc. Good luck enjoy the ride
#141438 11/29/2004 3:43 AM
Just noticed your from Glen Burnie, just take Rt 2 lights will turn red before you have to go over 45 anyway grin grin
#141439 11/29/2004 7:48 PM
62401
Yeah Jake -- a special welcome from the Maryland Stovebolters (also includes Bill Marlow and Doug Petersen).
I'd come up and visit, but I have a '49 with a splasher and a 4-speed and it would take a long time (45 MPH top speed, you know).
So again, wlecome and as has been said, be sure to ask questions -- that's what we're here for!
Regards,
John in St. Mary's County (America's First County!)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#141440 11/29/2004 7:55 PM
welcome aboard,,lot of good folks here that can help you out,,might consider looking in the tech section here also for various swaps...regards..Fred
Redryder pix
My Hotrod
#141441 11/29/2004 11:36 PM
Your tire size figures into it too. It probably had 17" wheels from the factory with a tire diameter of 33" to 34".
1951 1 Ton Completed
#141442 12/01/2004 3:50 PM
Junior Member
Junior Member
Thanks for all your input and welcomes. I figure 45 is a safe speed with no power steering no power brakes and bias tires (7.00 -17). Any faster than that I don't think the 8800 Lb. truck would handle to well! Thanks Again Jake
#141443 12/02/2004 2:21 AM
My 64 C-60 is governed at 60 MPH. Motor isn't working that hard I suspect it would run faster with no prob.
http://www.angelfire.com/mech/64_chevy/
