3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1411690 05/28/2021 3:25 AM
Hello everyone, I know it’s been quite a while since I’ve posted anything on the website, I have since moved from Michigan to Colorado which poses its unique changes to an engine when you go from 600 to 6000 feet above sea level. Anyway I have a 54 deluxe Chevy pick up with Hydromatic. What seems to be happening ever since I came here was once I put the vehicle in to drive there seems to be this clickety clack noise coming from the front of the engine one placed in drive like around the timing chain, maybe it’s the circumstances that the timing chain needs to be replaced, I don’t know, anyone have any interesting responses? thank you TODD
posey #1411693 05/28/2021 3:54 AM
what is your engine? a original six does not have a timing chain, just gears
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
posey #1411694 05/28/2021 4:10 AM
Insomniac
Insomniac
Fan blades hitting something? I once had a noise like that with the fan touching a block heater plug.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
posey #1411696 05/28/2021 4:20 AM
H Online: Content
Remove the fan belt for a short time and see if the noise is still there. That will help you determine if the noise is internal or external. A cold engine should be able to run for at least a couple of minutes without overheating, even if the fan and water pump aren't turning.
